Last Post: Martysf
0 Solar battery charging
Last Post: drumbrake
0 Iree's jukbox joint
Last Post: rubine
Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
Old 21st February 2011
curly h curly h is offline
Sportster/Buell Model: sportster 1000
Sportster/Buell Year: 1972
Sportster/Buell Model #2: 1200 custom
Sportster/Buell Year #2: 2005
Other Motorcycle Model: 883 l
curly h is an unknown quantity at this point
Default 72 sporty won't start
First try using this. I read all entries about starting problems. All are good but I still need help. My sportster will start sometimes but most of the time the starter just spins like solenoid is not engaged. New solenoid and battery with still the same problem. I think it is electrical. Any suggestions.
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
bad bendix drive maybe.
The most common cause is a battery not fully charged. I know you have a new battery, but did you fully charge it before installing it in the bike? The counter guys often say that it is ready to go out of the box. I never seriously listen to that.
Yes, I used a trickle charge overnight. Battery is reading 12.78 volts.
piniongear's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: FXDL
Being it's a 1972 model, don't you have a kick start on it?
If so, have you tried the kick starter?
If it starts with that then the problem is your Bendix drive is busted.
pg
No kick start. I had the primary cover off and all looks good. I just tryed jumping solenoid and oushing starter switch and same results. Maybe in the Bendix drive???
piniongear's Avatar
With the primary cover removed check the action of item 20 (the pinion gear) which is also shown on the assembly item 14 .
See illustration........
This gear should lock in a Clockwise direction and ratchet in a CCW direction.
What happens is the gear will malfunction and spin in both directions. The result is it will fail to turn the clutch basket gear and the engine.
When this happens, the fix is a new pinion gear (item 20). I previously called this a Bendix drive but this gear is what I was referring to.
pg
Old 23rd February 2011
After taking the starter housing apart it was the starter clutch. By hand when it was together it appeared to be good. Thanks all for the advice
piniongear's Avatar
The starter clutch ? I am not sure which item you are referring to.
What item number on the diagram did you replace?
pg
meanmechanic's Avatar
meanmechanic meanmechanic is offline
Sportster/Buell Model: sold XLH
Other Motorcycle Model: VRSCR + BMW R1200C
meanmechanic is on a distinguished roadmeanmechanic is on a distinguished roadmeanmechanic is on a distinguished roadmeanmechanic is on a distinguished road
pg
Prob the bendix as it is a one way clutch. In the past I've heard it referred to as that a few times.
