0 Cartridge Conversion?
0 How do you upshift?
Last Post: Sprtstr1200s
0 Photo Gallery for XL Forum Team Members!
0 This Week in my Shop
0 48 Handling
Last Post: Thyratron
Last Post: squekster
0 Error B2116 & 2117
Last Post: tester
5 To Hone Jugs if replace Piston Rings?
Last Post: groovemeisterus
0 79 starter housing torque values
0 Oil line routing on an 80
Old 11th March 2011
Baphomet's Avatar
Baphomet Baphomet is offline
Sportster/Buell Model: XL883L/1200 (Sold)
Sportster/Buell Year: 08
Other Motorcycle Model: FXDWG (wide glide)
Other Motorcycle Year: 2015
Baphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond repute
Default Help removing a broken plug.
Well, I was doing some service to the bike and part of that service was removing the plugs so I could turn the engine minus the compression. So I remove the rear plug with no problem. When I am removing the front plug I start to feel resistance after a few turns. I stopped and thought to myself, "I bet this bitch is going to seize". So I turned it back in about half a turn and sprayed WD40 along the exposed threads. I guess I didn't let it soak long enough because when I started to apply pressure again removing it then it broke off. I DO use an anti-seize, but apparently the front plug either didn't get enough or got overlooked. I've never removed a broken plug before, but I am thinking since a lot of it is already out of the head that perhaps someone can come up with an idea that might prevent me from pulling the head off. Here's a couple of pics of what I have to work with.
Old 11th March 2011
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
I'd grab it with vise grips and back it out. Happened to me years ago and had enough plug to get a grip.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 11th March 2011
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
Was about to suggest vise grips but khaskins beat me to it.
Good luck!
John Wayne - "The Shootist"
Old 11th March 2011
sunchild2071's Avatar
sunchild2071 sunchild2071 is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLH1200
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Chopped Shovel
Other Motorcycle Year: 1978
sunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant future
I can't see enough room for vice grips, but if they fit. Otherwise, if the machined recess is wide enough to allow one of those sockets that has the cammed action for stripped bolt heads, that may work for you. The needle type would not work.
In the realm of ideas that may not be so great, you could try and thread a nut onto the stub, protect the area and tack them together, then try twist it out.
In the world of things that suck balls, this is up there. Best of luck.
Disclaimer: I'm not the expert on this stuff, be sure to seek further opinion/knowledge.
Old 11th March 2011
Martinrobert's Avatar
Martinrobert Martinrobert is offline
Martinrobert will become famous soon enoughMartinrobert will become famous soon enoughMartinrobert will become famous soon enoughMartinrobert will become famous soon enoughMartinrobert will become famous soon enoughMartinrobert will become famous soon enough
needle nose vise grips should do it - how did that get so bound up?
Old 11th March 2011
flskevin's Avatar
flskevin flskevin is offline
Be annoyed Now;Ask Me How
Sportster/Buell Model: 1200XL Custom
Other Motorcycle Model: FLSTC Heritage Softail
Other Motorcycle Year: 2008
flskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant future
I found this on the web...
  1. Spray around the threaded area with a light penetrating oil like Liquid Wrench or Kano Kroil. Allow it to soak in for 20 minutes or more before trying loosen the broken plug. If this is the first spark plug that you attempted to remove, it's not a bad idea to soak the others. Usually if one is in poor shape, the others are probably not much better. Once you have decided that it has soaked enough, continue to the next step.
  2. Get an EZOut the size that will fit the hole where the ceramic used to be. You will need a very large EZOut Extractor. An EZOut (or Easy-out) is similar to a drill, except that it turns in reverse. As you turn the EZOut counter clockwise, its teeth grip the interior more tightly and turns it.
  3. Insert the EZOut extractor into the shaft where the ceramic part used to be. Make certain that the EZOut is the appropriate size. If it's too small, the teeth will not grip the sides.
  4. Turn it very slowly and carefully to unscrew and remove the old spark plug.
"... With Liberty & Justice for All." Must be 18, Void where prohibited, Some restrictions may apply, Not available in all 50 states.
Pastafarian Minister - Church of the Flying Spaghetti Monster
Dudeist Priest - Church of the Latter Day Dude
Old 11th March 2011
SuperTed's Avatar
SuperTed SuperTed is offline
Other Motorcycle Model: Fairlane 500
Other Motorcycle Year: 1964
SuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to all
Vice grips are a good idea, followed by some anti-seize on the new plugs! Lesson learned.
Please insert here:
- Poor attempt at cleverness/humor
- One too many quotes
- Oversized pic of my ride & lengthy list of upgrades
Old 11th March 2011
I was thinking those lines too, but when smashing out the ceramic to get the EZout in (it looks like the ceramic is currently flush with the break), keep some serious vacuum on the area so you don't drop ceramic bits down into the cylinder. If that happens, you may have some difficulty getting them out.
Old 11th March 2011
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
two slim nuts and a pair of needle nose visegrips....and lots of penetrating fluid.
In three words I can sum up everything I've learned about life: it goes on.
Old 11th March 2011
ChinCactus's Avatar
You might want to take that to a shop. It is possible a piece of the plug thread broke off and is jammed in there. If you force it, it may tear into the threads in the head on the way.
Good luck,
Jim
