0 V.o.e.s
0 Starter Worked, Then It Didn't
Last Post: smokey 2
0 05 sportster custom and bassani road rage
0 This place still sucks!!!
0 Coil suggestions please!!!
0 2009 Iron 883 Wont Start!
0 Rear sprockets
Last Post: 85IRONDIRT
0 Crank position sensor problems ??
0 07 883 Low .... lifting
0 Pictures of Evos that look Like Ironheads
Last Post: hotrodbiker
0 Rear shocks ?
Last Post: wachuko
Last Post: WKNDZ
Last Post: maltesefalcon
Last Post: SLW210
0 Speedo fog
0 Oil pressure switch testing
Last Post: Mission1
0 Best seat for long rides
0 Slip on alternative
0 Rear Shock length '81
0 Windage Tray
Last Post: SLW210
easy, headlight, mod, relocation, stock
Old 6th April 2011
vwclogan's Avatar
vwclogan vwclogan is offline
vwclogan is a name known to allvwclogan is a name known to allvwclogan is a name known to allvwclogan is a name known to allvwclogan is a name known to allvwclogan is a name known to allvwclogan is a name known to allvwclogan is a name known to allvwclogan is a name known to allvwclogan is a name known to allvwclogan is a name known to all
Ya no prob. I'll whip somthing up when I get home tonight.
$7 Turn Signal Relocation How to:
http://xlforum.net/forums/showthread.php?t=916453
Headlight Relocation Pics and How To(kinda):
http://xlforum.net/forums/showthread.php?threadid=1067978
Old 8th April 2011
vwclogan's Avatar
for got to up load yesterday, my bad, here ya go, this is just the general idea i went with, dimensions arnt exact, I've been getting home to late to have enough light to measure anything, but i believe the bottom bolt is a 1/4" allen and the I'm using a half inch bolt connecting the two together. I forgot the size of the headlight bolt but that is easy enough for someone to measure. the piece i added to the triple tree was just a scrap of i dont know what, but i just drilled and taped the bottom of it and made it for for my original headlight, im sure you can find something to file down or saw or something drill and tap just like i did. of you have a local steel yard, im sure you could go and ask them fro a scrap that 1x1x2 ya know?
Old 8th April 2011
sk883's Avatar
sk883 sk883 is offline
Sportster/Buell Model: 883xl
sk883 will become famous soon enoughsk883 will become famous soon enoughsk883 will become famous soon enoughsk883 will become famous soon enoughsk883 will become famous soon enoughsk883 will become famous soon enough
Thanks for the pictures! That helps! Kinda what I figured, but I wanted to make sure. Thanks for sharing!
Old 3rd August 2011
bp626indamix bp626indamix is offline
Sportster/Buell Model: i wish
Sportster/Buell Year: huh?
bp626indamix is an unknown quantity at this point
I like it, i like it alot.
