Last Post: big andy
0 Brake Squeek
Last Post: Tucsonmax1
0 Won't rev past 1200
0 Value of a Boattail?
Last Post: Monte03
Last Post: Jowniofownio
0 Not charging issue!
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Mikuni HSR42
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
Old 17th March 2011
Scrapper's Avatar
Scrapper Scrapper is offline
Scrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of lightScrapper is a glorious beacon of light
Default Boring 1200 cylinders to 1250
Has anyone bored their stock 1200 cylinders out to 1250 ?
stage 1 nightster 79 hp 81 ft/lb
Old 17th March 2011
tensejed's Avatar
tensejed tensejed is offline
tensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to all
others will chime in but if memory serves me correct they cant go past 1208. you need new jugs to go to 1250. im no expert but i think this to be true
Old 17th March 2011
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Can't get there from here. I believe Turbota bored his out to 1222 cc.
04/07 1275 BFH heads .590 cams S&S 1.725 rockers TC88A HSR-45 S&S ac LSR 2-1
Old 17th March 2011
Jimbos883's Avatar
Jimbos883 Jimbos883 is offline
Sportster/Buell Model: 883/1212 XL Custom
Sportster/Buell Model #2: XLCH STROKER
Sportster/Buell Year #2: 1959
Jimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to behold
1212 is the max.
Although Turbota and Dan from NRHS will correct me because NRHS did a bore for Turbo and it came to something bigger than that.
But my understanding is that 1212 is pretty much the max on stock cylinders, that would leave a bit for one larger bore if something happened to the cylinders / pistons.
2004 Vivid Black 883 Custom, CONVERTED With NRHS 1212 Cylinders, 10.5 to 1 NRHS Dome Pistons, Stage 2 NRHS 1200 XB Heads, SE .551 Cams, TC88A, All the Right Stuff
Old 17th March 2011
1222 is the max for 883 cyls. You can go about 1235 for 1200 cyls.
But this is getting really thin so we do not recommend more than 1212 for 883s and 1222 for 1200s.
Old 17th March 2011
Scrapper's Avatar
How do the 1250 size barrels have a thicker wall, the 1200 barrels are snug in the cases so they must be stepped outside the case line for strength or just a better material?
Old 17th March 2011
Yes they are stepped.
Old 17th March 2011
Scrapper's Avatar
Very clever.
