0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 Stage 1 results
0 Screw Loose's Repairs
0 C.O.B.B run west
0 Lowboy frame conversion
Last Post: Sportster-92
0 Spokes or Mags
0 Project of the day
Last Post: Baby883
Last Post: kaveebee
Old 19th March 2011
cajun1957a cajun1957a is offline
cajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of lightcajun1957a is a glorious beacon of light
Default Wet vs Dry clutch
Just interested in everyones opinion on clutches wet or dry. I have a wet clutch set up on 65-900, and have never had issues although originally it was dry clutch with the derby cover. I dont know of any differences in feel or performance. Anyone want to chime in on this?
randy
Old 19th March 2011
xHDrider's Avatar
xHDrider xHDrider is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: 650 Triumph Bonneville
Other Motorcycle Year: 1970
xHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of light
I think the dry clutches lock up better, however if your running a primary chain it has its own issues then. I would think it best to run a belt with a dry clutch.
chain with a wet clutch. (my preference any how)
I'm finding out my kevlar clutch hasn't like any lube I've tried. it works best dry.
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
Old 19th March 2011
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
chain needs oil, clutch don't care.....
run it wet.
thats my .02.
"lord of the Night Lite"
thank god for darwin ;)
Old 19th March 2011
16ouncePBR's Avatar
16ouncePBR 16ouncePBR is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLR Tribute
Sportster/Buell Year #2: 1962
Other Motorcycle Model: XLH
Other Motorcycle Year: 1968
16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light
Well, without getting too wordy, I think the dry clutch performs the best, but the issue is keeping it dry.
Now with the new wet/dry plates slipping is less of an issue, but I have recently found certain wet/dry plates stick together and are really hard to break apart when sitting and the oil gets gummy on them.
Going to try ATF this season out of desperation, but that is another topic.
Old 19th March 2011
flathead45's Avatar
i fear of cross contamination due to a failing transfer valve. i have had no trouble with my plates and striaght 50w oil in the trannie. if it sits too long (like a month or more) it slips slightly in 3rd, til i sling the oil off the plates with a good 55mhp+ blast then its all good again.
the main reason sporties slip is improper adjustment. not the type of oils used. follow the FM to the letter, take no shortcuts and it will treat you right for years to come
Old 19th March 2011
chevelle's Avatar
chevelle chevelle is online now
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
There is good info in this thread:
http://xlforum.net/forums/s...d.php?t=966372
There are opinions, and there is experiences, its up to the owner to decipher the two.
Old 20th March 2011
11B40 11B40 is offline
11B40 is a name known to all11B40 is a name known to all11B40 is a name known to all11B40 is a name known to all11B40 is a name known to all11B40 is a name known to all11B40 is a name known to all11B40 is a name known to all11B40 is a name known to all11B40 is a name known to all11B40 is a name known to all
Default This is always a good subject
The dry clutch performs right out of the garage. No sticking plates that rattle the hell out of the transmission on that first shift, no slipping. I personally think that the dry clutch along with the trapdoor was one of the Sportster's design triumphs. The wet plates work, but not as well, they were a less expensive way to make a clutch, if you have any real serious power, they can and do slip and wear out way quicker than dry plates. If you get on the dry clutch with the silver paint or sealant on those loose rivets, seal the cover with silicone instead of that paper gasket, it stays dry a long time and the plates can just be hit with a torch, dried out, sanded a bit and they are good to go.
Run the same engine oil in the primary is another bonus, and changing to a belt??? That's a reasonable solution to a non existent problem.
