0 first harley- help!!
Last Post: rickthrash99
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: blindfredy
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
0 Nighster seat on Iron
Last Post: BSA Bob
Last Post: Screw Loose Dan
5 Transmission HELP!
Old 8th April 2011
swtch7 swtch7 is offline
swtch7 is an unknown quantity at this point
Default diagnosing a potential fuel/relay problem
Hey Guys/Gals
I was trying to get some help on diagnosing a potential fuel problem on my 2007 EFI sortster 883. Its been sitting in the garage for about 1 year (started every 2 months or so) and no fuel stabilizer has been added.
Here are the symptoms.
-Bike turns over (Charged battery)
-when I would toggle the off/run switch I could hear a “clicking” sound.
I figured the gas gummed everything up so I siphoned it out, nasty smelly gas. I added some seafoam to clear out everything, then siphoned that out and added good gas. Same clicking sound.
I took the gas take off and proceeded to remove the fuel pump assembly out of the tank. When I would switch the off/run button to run I could feel the fuel pump clicking the first time….. tried cleaning it with more sea foam and toggled the switch again, this time to get no clicking or anything.
So, am I looking at a fuel pump issue or a relay problem?
Any help would be appreciated. Thanks!
Old 8th April 2011
I forgot to mention I did check the fuse's...I have not moved around the two relays yet...
I will pull out the multimeter when I get home this afternoon.
Old 8th April 2011
jguynn jguynn is offline
Sportster/Buell Model: None
Sportster/Buell Year: N/A
jguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nice
Having had a relay fail with no warning at all, I'd pull both relays then clean the contacts and put them back in. If the problem still exists, swap them and see if anything changes. If you can isolate on of the relays as bad, replace it but be sure to put dielectric grease on all of the relay AND fuse contacts after a good cleaning. The dielectric grease should help keep corrosion down.
One thing is for sure, it's easier to change the relay than it is the fuel pump.
John
Old 8th April 2011
psychodad1961's Avatar
psychodad1961 psychodad1961 is offline
Other Motorcycle Model: Heritage Softtail Classic
Other Motorcycle Year: 2007
psychodad1961 has much to be proud ofpsychodad1961 has much to be proud ofpsychodad1961 has much to be proud ofpsychodad1961 has much to be proud ofpsychodad1961 has much to be proud ofpsychodad1961 has much to be proud ofpsychodad1961 has much to be proud ofpsychodad1961 has much to be proud ofpsychodad1961 has much to be proud ofpsychodad1961 has much to be proud ofpsychodad1961 has much to be proud of
Besides a click, you should also hear a whirring noise as the pump pressurizes the injectors. Once pressurized, the pump should stop, usually after 1 or 2 seconds.
Sounds like the pump is gummed up and trying to spin but not actually moving.
This space (much like my mind) left intentionally blank.
Old 8th April 2011
ok i took it a bit further. I removed the fuel pump from the assembly completely and hooked up a 12v source. It would hum but not pump any fluid. I had the pick up submerged in the seafoam in a bucket, didnt do anything.... except hum
bad fuel pump? maybe a rebuild is in order?
Old 8th April 2011
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Welcome to the XLForum.
Old 31st October 2011
Hildreth's Avatar
Hildreth Hildreth is offline
Hildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really nice
swtch7, what did you find out about your fuel pump, what was the problem?
