Last Post: BluBeaSSt
Last Post: jcro61
0 90 in. Build
Last Post: mac93
Last Post: 883openpipes
0 New England 2018
0 Forty-Eight Special and Iron 1200 Sportsters announced today
0 Sportster or Street Bob
Last Post: seagullplayer
Last Post: conv90
Last Post: hscic
Old 11th April 2011
ridefree1 ridefree1 is offline
Sportster/Buell Model: 1975 xlh 1000 ironhead
Sportster/Buell Year: 75
ridefree1 is an unknown quantity at this point
Default whats up oil question
hey whats up. got me 75 going again, the freaking pushrods were to tight, closed up my valves, Mick told me to adjust them, did it and fired on the first push of the button. thanks all for commenting. this is the spot. ok, how much oil should be in the tank after a ride, i just did an oil change, it is less than half full, does this sound right, i have no leaks period. thanks
Old 11th April 2011
It should not use that much oil. I'll have to leave it to the other guys to offer suggestions.
Old 11th April 2011
the thing is, should the tank be full, like it is when you first add oil, or not.
Old 11th April 2011
Ivan RoachCoach's Avatar
Banned
Default Yes, most of the oil SHOULD have returned...
...to the tank, UNLESS the bike's been sitting awhile between rides.
If that's the case, it could've "wet-sumped" --- which means the oil in the tank could've leaked past the oil pump's check-ball and gone down into the crankcase.
If it did, it'll rise back up into the tank after running a few minutes or a few miles.
Old 11th April 2011
Sportster/Buell Year: 1972
I would say that it should run at a level within an inch of the fill open. Check level right after engine shut down (hot) with the bike up right. If you raise level ride the bike and then have 1/2 a tankful something is not right. Could've blown out the breather or got transferred to the primary.
Old 12th April 2011
i checked my primary and added a bit to it, i dont see nay oil under the frame or anywhere else for that matter, so i added a quart and a half, guess i'll ride it and see what happens. thanks
Old 13th April 2011
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
No smoke?Pull plugs look at them it's going somewhere.Do U have automatic chain oiler still running?
Murphy's Law :vvet:
