0 Tank swap
Last Post: Grymy
0 Oil Hose replacement help.
Last Post: McQueen
Last Post: jcro61
0 2016 48 Hesitating
Last Post: andy_t
Last Post: JensWest
0 Primary Oil INSANITY!
0 Fuel Pump Problems
Last Post: Blues
0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 FNG from OKC
Last Post: oreocat1
0 New From CA
Last Post: oreocat1
0 New in NM
Last Post: oreocat1
Old 29th April 2011
tink409 tink409 is offline
Sportster/Buell Year: 1981
tink409 will become famous soon enoughtink409 will become famous soon enoughtink409 will become famous soon enoughtink409 will become famous soon enoughtink409 will become famous soon enoughtink409 will become famous soon enoughtink409 will become famous soon enough
Default oil line replacement
anybody give me the quick lowdown on replacing the oil line that goes from the bottom of the oil tank to the oil pump? what kind of clamps to use? is there an easy way to get the oil tank line off and on with out pulling the tank?...thanks in advance
Old 29th April 2011
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Best clamps to use are those that are designed for Fuel Injection Systems. They help prevent the clamp from cutting into the tube. Here's a link to what I'm talking about:
Make sure you get the right size because there's not a whole lot of adjustment available.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 29th April 2011
Check out the pics in this Sticky ...
Oil Line Routing
http://xlforum.net/forums/s...d.php?t=920306
Also read thru the thread for more details on the routing.
Old 29th April 2011
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
I used fuel hose for the vent and return hoses and someone here recommended automotive transmission oil cooler hose, that's what I used for the suction. It has a little more rigidity, I was concerned at how soft the fuel hose was and didn't want to risk hose collapse on the suction side. Probably never would, but why take the chance.
I used the spring type clamps on mine, the kind you get with an automotive fuel filter. Didn't know if they would be adequate, but I've got a couple hundred miles on now and they are just fine, no leaks and they settle in quite nicely after a few heat cycles. I also like the looks, very basic and maybe a little vintage looking.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
Old 29th April 2011
Originally Posted by 2007Low View Post
I used fuel hose for the vent and return hoses and someone here recommended automotive transmission oil cooler hose, ...
The original hoses are 5/8 OD for the oil lines and 1/2 OD for the vent. Automotive hose is typically larger OD and are more difficult to run thru tight spots without kinking.
When i asked for hose by both ID and OD at an automotive parts shop, the counter guy actually squeezed the hose a little while measuring it to show me that it was OK.
So i always buy from my local indie bike shop. I always get the right stuff there.
Old 29th April 2011
2007Low's Avatar
Yeah we're kind of out in the sticks here, and don't have many resources available to us, especially in the way of Indies. So we're at the mercy of the hardware store in town and the automotive parts shop two towns away and 70 miles to the nearest dealer.
I've not had very good luck at the dealer, pretty frustating when you get there and the part they ordered in for you is aftermarket, when they told you it would be OEM.
But I was able to find the correct OD hoses and had no troubles with routing and clearance. Sure would be nice to have a capable Indy though.
My bike had the original hoses and clamps on it and they were all seeping a little bit. But I have to say that's not bad for 36 years and 30,000 miles.
Old 29th April 2011
Ivan RoachCoach's Avatar
Banned
Default I use 3/8" braided line on EVERYTHING...
...Oil tank, oil cooler, remote filter & gas tank.
You want high flow/low restriction.
The braiding is that extra layer of protection from sharp edges and heat.
Besides, using the same line size meanbs you only have to carry ONE piece of spare line, along with a brass connector/splice & extra clamps, in your tool bag for roadside repairs.
Learn to think how the earliest bikers did, before cell phones & "chase vehicles" --- simplicity, common sense & ease of maintenance.
Old 1st May 2011
heres a quick question that might be related if i over filled the oil tank by about 1/2-1/4 of a quart where if it was going to leak out, would it be comming out? this is an 81 btw
Old 1st May 2011
jharback's Avatar
Should have an overflow tube where the excess will blow out once it's warmed up. If you realize that it's over filled you can also take a Turkey Baster, put a rubber tube on the end of it, and just suck the excess out.
