Last Post: Martysf
0 Solar battery charging
Last Post: drumbrake
0 Iree's jukbox joint
Last Post: rubine
Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
Old 2nd May 2011
kowboi kowboi is offline
kowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura aboutkowboi has a spectacular aura about
Default Which cylinder runs leaner?
Front or rear?
Old 2nd May 2011
xena's Avatar
xena xena is offline
Assistant Administrator
My front runs leaner than the rear.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
Old 2nd May 2011
einheit 13's Avatar
einheit 13 einheit 13 is offline
Senior Master Bike Builder
Sportster/Buell Model #2: 883/1200 Hugger
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Bonneville America (904)
einheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to all
the front.
Life may begin at 30, but it really interesting around 150!
Old 2nd May 2011
Dave1200s's Avatar
Dave1200s Dave1200s is offline
Other Motorcycle Model: RD400, TS250 two-strokes
Other Motorcycle Year: 1977
Dave1200s is a jewel in the roughDave1200s is a jewel in the roughDave1200s is a jewel in the roughDave1200s is a jewel in the roughDave1200s is a jewel in the roughDave1200s is a jewel in the roughDave1200s is a jewel in the roughDave1200s is a jewel in the roughDave1200s is a jewel in the roughDave1200s is a jewel in the roughDave1200s is a jewel in the rough
Just for carb'd bikes, right?
I guess the fuel in the pilot and needle circuits has more time to lose velocity and maybe even see a level drop in the greater time it takes the front cylinder to pull from the carb.
I don't know if the slide moves much in synch with the pulses at normal operating rpm range and not sure how that would affect mixture strength, but I'm sure somebody on this forum does!
Good thing that the front cylinder gets more cooling air tho.
Old 2nd May 2011
einheit 13's Avatar
I have only seen it on carb'd bikes. Big twins and sportys both. one of the reasons the front runs hotter. Jim McClure ran a sniffer on a few of his gas bikes and noted that the rear had to run a bit fat to get the front into the 'safe zone'. He was also one of the first to play with angling the carb to favor the front to help combat a lean condition. The old Triumphs even favored one cylinder when they ran a Tiger head (single carb) and Amal/Triumph/Red Circle/Baxter had a special high performance manifolds that kicked the carb to the right.
Old 2nd May 2011
Dave1200s's Avatar
I hadn't heard Jim McClure's name in a while.
Some of the T/F Harleys actually have an air bleeder valve on the rear leg of the manifold to try and get the two cylinders at the same temp during staging! Since they're running multi-channel data-aq and that includes head temp's.
Old 2nd May 2011
einheit 13's Avatar
I grew up around his shop and worked there when I was teenager. I had an old Virago he hot rodded that I raced at the dirt drags. I was 12 and it was so fast, they moved me into the 1200cc hot street class. He helped me build my first hot rod Triumph that ran on alcohol...it was a street bike! Had to use an HD trans because none of the brit trannys could take the abuse. 750cc pre unit with the heads flipped and the 2 932s could suck up small animals and children. Had to run a mag wheel out back because it would destroy spoke wheels. Used a rotary pump to pressure feed the top end with its own return line. its was way too much bike for the street (and me) and he talked me into selling it to a guy from the west coast when we were in Maryland at the track in 94. Jim was a cool dude....
Old 3rd May 2011
whittlebeast's Avatar
Other Motorcycle Year: 2008
With the EFI bikes about 56% of the fuel comes out of the front injector.
AW
Old 3rd May 2011
flashedwards's Avatar
flashedwards flashedwards is offline
flashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant future
Wow, whittlebeast...there is a 6% difference!...you would think that Moco would have done something to address that issue. One cylinder running stronger than the other could not saying that it would but could put undue torque on the crankshaft. When I first got my bike I put X14iED's on it but then later after talking to Steve at Nightrider about the front cylinder running leaner I switched to AF-XiED's because they are individually adjustable and I was able to fatten up the front. Now that I have a Power Commander the situation is resolved.
Flash
Trying to balance being an "unknown quantity" and a "known associate" ....it's tuff
2009 XL1200N Nightster...SE Heavy Breather>SE SP black slip-ons w/modified Cycle Shack baffles>Speedway Instruments MicroTach+>Super Brace>Kriss headlight modulator. Willie G skulls @ gas cap,derby and timer>Misc. black nut and bolt covers>Garage Leathers solo bag>Mustang Vintage 12.5" solo seat>LED taillights>10.75" RK air shocks>G2 Ergonomics Quick Turn throttle>Power Commander V>Giving 10R12 plugs a try.
76 HP X 79 TQ
Ol' Dirtbeard of the Cracked Craniums MC
Old 3rd May 2011
einheit 13's Avatar
I figured that since the cylinders have their own injectors, it would be what ever the o2 sensor says it wants. i put mini squirts on my 81 XJ650 and the sniffer and 02 sensors both confirm that the 2 center cylinders need a little more fuel to help with heat. So they are tuned with a touch more fuel. 14.6, 13.9, 14.0, 14.6.....best performance and cleanest burn on the dyno and with the maps. i don't know if HD uses stand alones, but the 2 injectors should be independent of each other and flow should be separate. All this is based upon you meaning that the front gets 56% and the rear gets 44%....doesn't make sense if that is indeed what you mean. 56% of the fuel that pump is pumping for correct A/F mixture or 56% of the fuel that the injector can flow??
