0 2016 48 Hesitating
Last Post: Screw Loose Dan
0 Ei
0 24633-77 Breather assembly
0 Newbie CV rebuild
Last Post: Matt Black
0 ‘68 XLCH...transmission
Last Post: Larry May
Last Post: Yochstein
Last Post: Jheitt
0 Salutations y'all
0 New member in MD
0 New from Utah
0 New England 2018
Old 12th May 2011
avl8386 avl8386 is offline
Sportster/Buell Year: 1966
avl8386 is an unknown quantity at this point
Default Figured out what happened sunday
I pulled the front exhaust pushrod tube and the pushrod dropped out with it.
Now the question is why? Bike started first/second kick everyti,e ran great for 70 miles at 65 and then poof no front cylinder. Seemed like it was in adjustment. Any ideas other than it being loose>
Old 12th May 2011
hcrashster's Avatar
hcrashster hcrashster is offline
Sportster/Buell Model: XLH Spinegrinder
Sportster/Buell Model #2: XLCH Frankenstien
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Triumph Groanyville
Other Motorcycle Year: 1972
hcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud of
Not centered in rocker shaft cup? Set nut worked itself loose? Nut not tightened? Bad MOJO?
Old 12th May 2011
DirtyCory's Avatar
Sportster/Buell Year #2: 1972
Other Motorcycle Model: Sportster 48
Other Motorcycle Year: 2010
DirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud of
maybe the locknut on that adjuster wasnt tight enough and vibration loosened it up. did it adjust back to how it is supposed to be okay? do a compression test to check your valves
Old 12th May 2011
66xlch 66xlch is offline
Master Bike Builder
Sportster/Buell Year: 66
Sportster/Buell Model #2: 67 XLH, 63 XLCH
Sportster/Buell Year #2: 67
Other Motorcycle Model: FXRT
Other Motorcycle Year: 91
66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about
Stuck valve?
Old 12th May 2011
I havnt gotten further than taking it apart. I took it apart in the back of my trailer last night before i went to bed (great part of being a houshold mover is I can carry it with me). I just got home tonight so i am gonna work on it friday probably. I will check the locknut and adjuster though.
If it wasn't centered you think it would run 70 miles before dropping??
Old 12th May 2011
hcrashster's Avatar
Didn't even occur to me, 66. Could very well have been a stuck valve.
Old 12th May 2011
DirtyCory's Avatar
i wouldnt think so with the way these bikes vibrate and shake.
Old 12th May 2011
hmmm stuck valve theres a good one. Im gonna put it back in and run it and ig it happens again i guess its off with the rocker box
Thanks for the ideas
Old 12th May 2011
DirtyCory's Avatar
just reset the valve and do a compression test and it will tell you if your valve is stuck
Old 12th May 2011
Master Bike Builder
It could also be a bad tappet roller. That would be an easier fix, at least.
