Last Post: ZCarFan
13th May 2011
Posts: 60 Sportster/Buell Model: XL1200X Sportster/Buell Year: 2011
From the SE Catalog;
G. SCREAMIN’ EAGLE® PRO HIGH-FLOW AIR
CLEANER KIT FOR SPORTSTER® MODELS
This air cleaner kit provides increased air flow when
used with stock, or Screamin’ Eagle carburtetors. It
includes a composite backplate, an air cleaner cover
adapter, and a high flow, washable element that does
not require oiling. In addition, the breather system has
been redesigned to route breather gases directly into
the inlet of the carburetor to minimize excess oil in the
air cleaner assembly. Kit comes complete with all necessary
components and assembly instructions required.
For race application only.
29042-04A Fits ’04-later XL models with stock
air cleaner cover. Harley-Davidson®
Air Cleaner Cover P/N 29742-04
requires separate purchase of
adapter kit P/N 29848-04. $109.95
29066-03 Fits ’88-’03 XL models. $109.95
Thanks for the help Big-Ed. See the bolded information above......found that information on this sites archives. Thats why I was confused. If that is indeed what I have (which it sounds like what I have exactly, but maybe not) then the filter would not require oiling. Would it still be OK to oil it? I am aware that the oil is what traps the grime/dirt/bugs from entering the engine (I run a K&N on my Tahoe), but did not want to oil it if it is supposed to be run dry.
13th May 2011
Posts: 914 Sportster/Buell Model: Sportster Sport XL1200S Sportster/Buell Year: 1998 Sportster/Buell Model #2: Fatboy 1450 FLSTFI Sportster/Buell Year #2: 2002 Other Motorcycle Model: Kawasaki KDX125sr Other Motorcycle Year: 1991
Originally Posted by Bedore
Thanks for the help Big-Ed. See the bold above......found that information on this sites archives. Thats why I was confused. If that is indeed what I have (which it sounds like what I have exactly) then the filter would not require oiling. Would it still be OK to oil it?
The reason I think you are being confused is that the newer SE kits (from about 03-04 then 04-up) didnt use a K&N filter, they use a high flow what looks like white paper type cleanable element (that has the warning not to oil it stamped into it)
The kit you have fitted on you 1200s is an 90's era SE kit & that is when K&N supplied the filters to HD..
1998 XL1200S - Harley 2-1 fitted with V&H SS2R, SE race ignition (7500rpm) with matched SE coil, SE yellow leads, NGK Iridium spark plugs, NRHS HurricaneFlow 3" centre hamcan filter, usual 'S' engine internals (w-grind cams, flat top pistons & 10:1 higher comp twin plug heads), SE heavier clutch spring. Soon to have SE 42mm hsr mikuni carb..
13th May 2011
Originally Posted by Big-Ed
The reason I think you are being confused is that the newer SE kits (from about 04-up) didnt use a K&N filter, they use a high flow what looks like white paper type cleanable element (that has the warning not to oil it stamped into it)
10-4 thanks again. That makes sense....but just wanted to be 100% sure before I go and oil it. Looks like the previous owner definitely paid the tax on it before I got it. Saves me some cash for sure.
