0 Not measuring any crankshaft endplay
Last Post: nakina
0 Manifold Leaks Gone !!!!
Last Post: cazz1000
Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
Last Post: x1_guy
Old 26th May 2011
TABER33's Avatar
TABER33 TABER33 is offline
Sportster/Buell Model: Iron Head 1000cc
Sportster/Buell Year: 1976
Other Motorcycle Model: Fatboy
TABER33 is an unknown quantity at this point
Default Front Brake Problem???
So i just got back from a little ride and when i pulled in my front brake was really hard to pull, like it was built up. after a while it went back to normal but now it happens every time i ride. any ideas on what it could be and what i can do to fix it??? thanks...
Taber
Old 26th May 2011
Mosey Mosey is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
Sounds like your system needs a good flush. Might have some debris clogging up the pressure relief hole (the splooge hole!) in the master cylinder. If it was mine, I would dismantle the entire magillicuddy and clean the M/C, calipers and lines with brake cleaner or rubbing alcohol and blast with compressed air.
Let us know how it goes.
Old 26th May 2011
mycle1000 mycle1000 is offline
Sportster/Buell Model: xlx61
Sportster/Buell Year: 85
Other Motorcycle Model: yamaha vstar 650 custom
Other Motorcycle Year: 00
mycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to beholdmycle1000 is a splendid one to behold
at the very least flush and bleed with fresh brake fluid and see what that does. if it is still bad, go to rebuild mode of master cylinder and caliper. brakes are good to have and need attention when they get wierd.
85 xlx61 (with a million miles and a million mods)
05 xl1200r (bought used)
00 vstar650 (for the wife)
Old 26th May 2011
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Taber......... to THE FORUM!
As mentioned.....it's time for a good look. It sounds to me like the pads may be binding on the pins. Might be as simple as cleaning them and putting a dab of never seize on them.
Before you flush and start bleeding, see if you can get to the pins, and try a squirt of WD 40 and see if that helps. If it does.....you know where your problem is.
Stuff: YES
Old 6th June 2011
TABER33's Avatar
So i figured i would bleed with fresh fluid to see if that was all it was first, i drained out what was in there and put fresh stuff in, but it wouldnt bleed. i took the hose off and found that the master cylinder isnt pumping anything through. does this sound like it would be part of the problem or a whole new one??
Old 6th June 2011
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Time for a master cylinder rebuild
Old 6th June 2011
Tin Man 2's Avatar
Tin Man 2 Tin Man 2 is offline
Sportster/Buell Model #2: XL1200, 2003
Other Motorcycle Model: Suzuki T250 Hustler
Other Motorcycle Year: 1971
Tin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond repute
It is always hard to get an empty master cylinder to pump up after it is empty. Try a Mitivac bleed pump at the wheel cylinder to suck the fluid through. If your not in a hurry you can just fill the Master, hook it up and let it sit with the bleeder open for a few hours, Gravity never fails!! Once you get a drip going just bleed as usual.
