0 Not measuring any crankshaft endplay
Last Post: nakina
0 Manifold Leaks Gone !!!!
Last Post: cazz1000
Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
Last Post: x1_guy
Old 1st June 2011
keelerb keelerb is offline
keelerb has a spectacular aura aboutkeelerb has a spectacular aura aboutkeelerb has a spectacular aura aboutkeelerb has a spectacular aura aboutkeelerb has a spectacular aura aboutkeelerb has a spectacular aura aboutkeelerb has a spectacular aura aboutkeelerb has a spectacular aura aboutkeelerb has a spectacular aura about
Default Removing clutch release plate retaining ring?
I'm referring to the one that holds the release plate on - I'm trying to remove the clutch as an assembly. This is NOT the one you need to release pressure on the diapragm spring to remove.
Anybody got any tips? This thing is not a normal snap ring - there are no "hole" for the snap ring pliers to fit into - just a sort of "slot." My snap ring pliers are getting no purchase whatsoever. Tried needle nose pliers, small screwdrivers - nada!
Any advice will be greatly appreciated. Thanks - Brian
Old 1st June 2011
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
I use two screwdrivers, one to pull one end out and the other to slip behind it from
going back in while you move the first one.
My 2003 did have holes in the ring though.
Old 1st June 2011
Thanks Decman
Old 1st June 2011
steelworker's Avatar
Other Motorcycle Year: 2016
It should have holes in it for circlip pliers (at least mine has, and I know for a fact that 2006 XB Buells also did), and I can't see why they'd change it. After you do get it off, I'd check and maybe get a replacement.
Old 1st June 2011
DIESEL's Avatar
DIESEL DIESEL is offline
mine had holes in it....hmmm.
Old 2nd June 2011
Problem solved.
The problem? That I'm a dumbass. I was trying to remove the ring that holds the diaphragm spring in place (without compressing the spring - good thing i DIDN'T succeed)! Finally looked deeper and saw the one I should be removing.
Thanks for trying to help. Some things (people!) just can't be helped!
Old 2nd June 2011
SpartanDen's Avatar
SpartanDen SpartanDen is offline
SpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond repute
and some are smart enough to come here for answers!!!
Denny
Old 2nd June 2011
Nicktater's Avatar
Nicktater Nicktater is offline
Nicktater is on a distinguished roadNicktater is on a distinguished road
Old 2nd June 2011
glad you were not successful in getting that off or you could have been hurt badly.
Old 4th June 2011
Thanks for your advice and kind words folks. Yeah, I'm a dumbass, but a living and non-maimed one, so yeah, it coulda been worse!
Ride safely, all.
