5th June 2011
Posts: 1,770 Sportster/Buell Model: XLH Sportster/Buell Year: 1976
Metallic Primary Oil
Well, today I decided to play doctor to my primary because I kept noticing that sound I was describing in an earlier thread, so I drained some primary fluid into a small saucer and saw very small what I presume to be tiny aluminum flakes, I'm thinking maybe the chain is so loose its scraping the casing a bit and it's coming off, so what should I get done here? You can also tell there's motor oil coming into the primary casing as well, so when I tear the cover off I'm going to have to close the transfer valve. If anyone can post a picture and details how to do so they'd be much appreciated and what should I look for? do? ect....
also how to tighten the chain in there would be helpful info, I'm about to get a manual here in the next week, shipping n such, but would like to get some input on whats going on
5th June 2011
Try this, drill and and tap the valve for a 6-32 screw and Loctite the screw into the hole. Engine oil stays in the engine and trans oil stays in the trans.
http://www.ironheadcycle.com/pages/howto4.htm
6th June 2011
If your chain is properly adjusted, it probally wont hit the cover. But I do know a guy who insitsts on downshifting at high revs, that puts ALOT of slack on the TOP of the chain. Even adjusted right, his cover right above the engine sprocket is chewed to hell.
6th June 2011
Posts: 9,331 Sportster/Buell Model: XLCH 1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 75 motor in Norton frame. Other Motorcycle Model: 42WLA 45, Harton, Narley Other Motorcycle Year: 1942
Some one posted a page from the manual recently on primary chain adjusting.
Search with the Google search at the BOTTOM of the page should find it.
Look too at the tensioner and see if the metal is coming from the chain wearing through the nylon pad.
