0 1972 tank fitment
Last Post: 72 Ironhead XLH
0 Blues & Brews 2018
Last Post: tvon
Last Post: tvon
0 Help me with gas cap...
Last Post: geoff
0 Turn signals
0 bike went for a slide
Last Post: chevelle
0 Cad Plating
Last Post: DirtyHarry68
Old 5th June 2011
dawg dawg is offline
Sportster/Buell Year: 1982
dawg is an unknown quantity at this point
Default 1982, need a pic or two for reference clutch cable routing
1982, replacing parts in the chain case, clutch, etc. The manuals I have are old scan copies so it's hard to see the black and white photos. It shows that there is supposed to be a clip/clamp on 1982 models that appears to be coming off the rocker area instead of the downtubes. I need a photo of this clamp pn#38623-68 (-68T) as mounted on the bike so I know exactly where/how it goes. I also need a pic of how the cable is routed up top from the perch down to the above mentioned clamp so I know how to route it properly. Thanks much
Old 6th June 2011
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Here's a pic of my '83 - I'm pretty sure it's the same. As for cable routing, it really depends on the bars you have. Most had the cable crossing over the bar and going straight down behind it through the bracket you're asking about.
Old 6th June 2011
I tried using a bracket similar to that on my 1980 and on my 1978. I found that it restricted the cable too much. IMX it is best to have the cable routed thru the path with the least resistance/interference/whatever.
And keep the cable well lubed!
Old 6th June 2011
Thanks guys. I'll give it a shot and see what works best.
Old 6th June 2011
Mosey Mosey is offline
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
My '82 doesn't have that type of bracket...
In fact, the cable ran wild and free! I hope you can see in this pic that it is just sitting out there in the breeze. Since the factory cable is very heavy duty, it doesn't flop around at all.
The only thing holding it in place is the left fork tube.
Old 6th June 2011
1979XLH 1979XLH is offline
Sportster/Buell Year: 1979
1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough
i let mine hang free.. i tried to tuck it but it restricted it to much.
Old 6th June 2011
83XLX's Avatar
Yeah, that's why I said the routing really depends on the bars you have. I put a short cable on mine and routed it beside the headlight and through the stock bracket - it doesn't bind, works fine, looks clean, and is out of the way.
Old 6th June 2011
nikki's Avatar
nikki nikki is offline
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
I used the same routing on my 82 xls with stock buckhorn bars . Nikki
the difficult can be done immediatey the impossible takes a little longer
Old 7th June 2011
mikethebike61's Avatar
Over and behind the handle-bar next to the neck and down through the factory frame guide to the primary. Simple, keeps cable tucked in away from 'stuff'.
Old 7th June 2011
The problem i found on both my bikes with running the clutch cable thru anything is when you turn the bars all the way in one direction or the other. The cable can easily get wrecked. So it is out in the open for mine. No problems there as the cable is stiff enough.
