0 Head gaskets.
0 1967 XLCH stroker project
0 Stock 883 cold blooded
Last Post: oldboy
0 New to Harley
0 79 ironhead
0 THE Trainspotting Thread
0 rpm jump pulling in clutch
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
0 Value of a Boattail?
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
Last Post: jammantoo
Last Post: lugster
Old 11th August 2005
MusclePump's Avatar
MusclePump MusclePump is offline
Sportster/Buell Model: 883L
MusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really nice
Default Help! - No Lights!
On my twenty mile trip home tonight I had about half a dozen people pull up beside me and yell over that, on a motorcycle, I had no lights!!! I flicked the high/low switch a hundred times, nothing happened. When I got home, I turn it on/off, on/off and nothing happens. And as far as I know, every bike in the last decade or so has lights that turn on with the bike. And mine used to! How do I fix this???
Jeffytune for President!
2005.883L
SEII Pro Slash Down's | Hurricane A/C
Moker's Avatar
Moker Moker is offline
Sportster/Buell Model: 883C
Moker has disabled reputation
check the fuses?
itsshemp's Avatar
itsshemp itsshemp is offline
Other Motorcycle Model: Banshee
Other Motorcycle Year: 1996
itsshemp is an unknown quantity at this point
sound like it would just be a fuse. Hopefully so!
You will still need to figure out why it blew a fuse, if that turns out to be the problem.
Do ya have tailight, marker lights?
ItsShemp!
Are We There Yet!?
2005 XL1200C
http://shemps05sporty.myphotoalbum.com/
_____________________________________________
http://i69.photobucket.com/albums/i73/kornbilly/Bike1resize2.jpg
Y2K's Avatar
Y2K Y2K is offline
Other Motorcycle Model: Electraglide classic
Other Motorcycle Year: 2000
Y2K has disabled reputation
Sounds like a warranty issue to me,take it in and say fix it!
Electraglide Roadtripper
Moved On Moved On is offline
It's doubtful that you blew both the high and low beam at the same time. Usually if one blows the other is still good. Have you ever taken the bulb out? The bulb may have broken glass if you touched it and left a finger print behind or if it got some water inside.
Check the fuses first.
Then take the headlamp out and look at the connector to the bulb. It's pretty common (on higher milage) Sporties for the connector to come loose from vibration, then arc and over heat and melt. If that happened you will need to get a replacement connector from the dealer or an auto parts store. It should be under warranty. Putting some dielectric grease on the connector is a good thing to do to reduce the chances of burning out a connector.
If thats all okay, then take the bulb out and inspect it for blown filaments or broken glass.
The connector should be under warranty, but a blown/broken bulb or a blown fuse probably won't be covered, so do a little investigative work first. If you find a problem that you think should be under waranty, put it all back together and take it too the dealer. They won't warranty a burnt connector if you replace it and just take the burnt part into the shop.
Gazza
warpig warpig is offline
Sportster/Buell Year: 1991
warpig has disabled reputation
Does HD uses fuses now?
Mine has a self resetting circuit breaker on the headlight circuit. If it trips it automatically resets as it cools off. I had a short once when I was doing some wiring and tested it. It resets in just a few seconds cycling the light off and on.
MusclePump's Avatar
Is it possible I did this when I took off my seat??
Moker's Avatar
the fuse panel is located on the left side under the cover. simple as heck to check
Did you cycle the key switch fully?
I have seen this on some bikes, they will run in the accessory position.
Take the key out, and slowly insert it and turn it so you feel both notches.
Are the lights on now?
Juggle the key, do they flicker?
Let me know MP.
MusclePump's Avatar
Let me know MP.
it was all forward, tried a dozen times to be sure. no go
