Last Post: mct496
Last Post: conv90
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
Last Post: blindfredy
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
Old 8th June 2011
hondo hondo is offline
Other Motorcycle Model: 2000 ZX12R/1998 T595
hondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura about
Default Diagnostic Trouble Code U1097
What's the worst that can happen if I keep riding with this DTC? The only problem I've noticed is that the speedometer does not return to zero, it always stops at 5mph. The speedo is otherwise dead nuts accurate when compared to a GPS unit and a 5-mile speedometer test area.
Yellow Pearl 05 XL1200R, Mikuni 42, .551, Doherty AC, Golan FV, DTT, Modified SE mufflers
Old 8th June 2011
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
Did you try clearing the code?
Does it come back?
Old 10th June 2011
It's back so I'm guessing it's a current code. Still runs fine, my only worry with this code is if it could leave me stranded?
Old 10th June 2011
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
U1097 indicates a loss of speedometer serial data to the ecm. Your speedo may be jacked, but I doubt it's something that will leave you stranded.
Sic Semper Evello Mortem Tyrannis
