0 Brake Squeek
Last Post: Tucsonmax1
Last Post: cazz1000
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Not charging issue!
0 1977 Bright Blue
Last Post: robistro
Last Post: T^2
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
Old 12th June 2011
marknett's Avatar
marknett marknett is offline
Sportster/Buell Model: 1200 sportster
marknett will become famous soon enoughmarknett will become famous soon enoughmarknett will become famous soon enoughmarknett will become famous soon enoughmarknett will become famous soon enoughmarknett will become famous soon enoughmarknett will become famous soon enough
Default Crane ignition
WHAT are the advantages to changing over to programmable ignition like crane . I have a 1996 1200c with screaming eagle coil, s&s super e carb, vance & hines straight shots . Will it increase power or give a noticeable feel n performance? Thanks
Old 12th June 2011
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
It's programmable or "tunable". Easier to tune ignition for optimal performance.
Old 12th June 2011
mach1charlie's Avatar
mach1charlie mach1charlie is offline
Sportster/Buell Model: XL 883/1200
Sportster/Buell Year: 92
Other Motorcycle Model: RZ350KLR650GT750KZ1000C10
mach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the rough
Well there is no horsepower to be gained in a "hotter' ignition; as long as the cylinder is ignited, does not matter if it is ignited with a match or a blow torch.
And more timming is not more power. The very efficent high compression evo sportster chamber will make the same horsepower from 22 to 28 degrees (although it is lazy comming up on the rpms)
The only reason I run a crane ignition on my dyno winning sportster is to raise the rpm limit
Ok I said my piece, flame on. (next subject how much HP from roller rockers)
Old 12th June 2011
marknett's Avatar
I have a screaming eagle ignition controller that is stamped 8000 rpm's . So I quess i dont need to upgrade to the crane?
Old 13th June 2011
Kudofo's Avatar
Kudofo Kudofo is offline
Sportster/Buell Year: 1987
Kudofo is a jewel in the roughKudofo is a jewel in the roughKudofo is a jewel in the roughKudofo is a jewel in the roughKudofo is a jewel in the roughKudofo is a jewel in the roughKudofo is a jewel in the roughKudofo is a jewel in the roughKudofo is a jewel in the roughKudofo is a jewel in the roughKudofo is a jewel in the rough
Uh that's not even close to true. If you light the cylinder with a hotter spark you can more efficiency light more product for more efficiency. If you make compression high enough you need to add in another plug for an hotter extended spark.
Timing can make a significant amount of power difference. I have seen just timing bring motors from 75hp to well over 100hp with just the advancement of timing. Its extremely important that you light that fuel off so it has enough time to completely burn while shoving that piston down with as much force as possible. To early and your just canceling out power. Proper timing with a VOES advance can make a significant difference in power.
1987 Harley-Davidson Sportster 883 conversion 1250. Python 3 exhaust, S&S super E Carb, Ported and polished heads, Ported intake manifold, ev3 Cams, Dunlop 401 F, Dunlop K591 Rear, Dual disc front brakes, Progressive front springs, Rear 401 springs/shocks.
Old 13th June 2011
Its your story, tell it how ever you like.
I bet 2 plug heads and multi eletrode plugs would really make hp!
Wow 25% increase in hp from a timming adjustment, I just will not comment.
A vacum operated electrical switch makes more power ? is that why harley put it there?
On a serious note, timming is an adjustment for chamber efficiency, the more efficient your chamber the less timming you need.
And the timming "curve" has nothing to do with horsepower, its all in by 3000RPM
Flame on.
Old 13th June 2011
xHDrider's Avatar
xHDrider xHDrider is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: 650 Triumph Bonneville
Other Motorcycle Year: 1970
xHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of light
I think the crane ignition was very worth while. I'm running the HI 4E. running single fire with an super coil. my top end feels a lot stronger. it pulls to the limiter, before it was lazy a thousand RPM's before it hit it.
also the multi-spark works well for me, makes the response better at the lower RPMs and runs better and starts easier when cold.
I felt a big difference between 5 and 7 on the advance curve. I think it helped a lot power wise, over my stock duel fire. (was using a 1200-J module, which felt better then the stock 883 module)
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
Old 13th June 2011
LuxBlue's Avatar
LuxBlue LuxBlue is offline
I'm running the TC88A in mine and the timing curve map I got from Rico (Triple Deuce Map) gives my bike much more power than the stock ignition. I'm running near 35 degrees advance and it pulls like a train.
Old 14th June 2011
marknett's Avatar
I'm sorry , that screaming eagle ignition module has 6800 rpm's on it not 8000
