Last Post: Diogenes415
Last Post: 883openpipes
Last Post: Blowupster
0 Stock vs. Modified
Last Post: blindfredy
0 rethreadable?
Last Post: senseigreen
Last Post: mct496
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
0 first harley- help!!
Old 17th June 2011
Gone Gone is offline
Default 1994 evo 1200 (bike stalls)
Bike has 2000 miles I just bought it Idles perfect I put about 80 miles on it last week end ran great until the end of ride . At higher RPM the tach goes whaky and it starts to hesitate or stall when I let off the throttle it idles fine took it out last night rode a couple miles ran good then started to act up again same thing tach gone whacky and stall like but idles perfect HELP PLEASE!!!!!!!!!!!!!!! 1994 XL1200 EVO
Old 17th June 2011
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
Corrosion in your ignition cone maybe? Loose battery connection?
Seems like an electrical issue.
Old 17th June 2011
Big-Ed's Avatar
Big-Ed Big-Ed is offline
Sportster/Buell Model: Sportster Sport XL1200S
Sportster/Buell Model #2: Fatboy 1450 FLSTFI
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Kawasaki KDX125sr
Other Motorcycle Year: 1991
Big-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to all
+1 on that, sounds like it may be electrical..
Maybe the coil might be letting go & breaking down under the higher rpm strain...
Also, maybe a spark plug going bad with the higher rpm strain??...
1998 XL1200S - Harley 2-1 fitted with V&H SS2R, SE race ignition (7500rpm) with matched SE coil, SE yellow leads, NGK Iridium spark plugs, NRHS HurricaneFlow 3" centre hamcan filter, usual 'S' engine internals (w-grind cams, flat top pistons & 10:1 higher comp twin plug heads), SE heavier clutch spring. Soon to have SE 42mm hsr mikuni carb..
Old 18th June 2011
94Sporty's Avatar
94Sporty 94Sporty is offline
Sportster/Buell Model: 883 XL converted to 1200
94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough
Sounds like a vibration problem affecting the electrical. Mine did the same thing at about 3000 to 3500 rpm. Turned out to be the ignition switch. Also check for loose connections (especially battery cables), circuit breaker, kill switch on handlebars. Roger
Old 18th June 2011
m.breen m.breen is offline
m.breen has disabled reputation
Same thing happened to me on my 1993 sportster. It was a loose battery connection, positve side if I remember correctly, really had to crank that bolt on tight.
Old 18th June 2011
vlmuke's Avatar
vlmuke vlmuke is offline
Other Motorcycle Model: Fat Bob
Other Motorcycle Year: 2015
vlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to behold
+1 on loose connection anything that works intermittantly or goes whacky first thing is to check for a loose connection somewhere
Old 18th June 2011
CharlieB's Avatar
CharlieB CharlieB is offline
Sportster/Buell Model #2: XLH 883 Deluxe - sold now
Sportster/Buell Year #2: 1986
Other Motorcycle Model: FXDWGi
CharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really nice
Wacky-tachy... suggests lack of 12v going to the positive side of the coil - OR - the sensor under the nosecone has an issue, or its wiring does.
This isn't really brain surgery. Your eyes may just be your best troubleshooting tool. Look for green (corroded) connections and or plugs. Look for something out of the ordinary - such as - previous owner did some sort of splice that isn't too Kosher.
First thing I'd check, is the Deutch connector under the frame, amidships. If it goes bad, you lose all ignition and tach.... hmm sound familiar (ask me how I know). Take it apart, make sure no water has gotten in there (er... its under the frame where ANY road water will douche it). After that, check the screw down connections on the coil, then battery + wire, both ends. Check to make sure the breakers under the seat are well seated, and that the sockets haven't gone green and corroded. Check the BIG plug(s) at the steering head for corrosion.
You may just want to pull the ignition sensor cover (end of the nose cone), and have a peek inside. Maybe get a new seal for it (cardboard like thing... double up on 'em, works better).
Old 18th June 2011
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
+1
This often turns out to be a battery cable. They're infamous for causing these type of problems. Get a wrench on both ends, don't just wiggle it with your hand. BTW, welcome to the forum.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 20th June 2011
99hugger 99hugger is offline
Sportster/Buell Model: hugger
99hugger is an unknown quantity at this point
mine did something similar too. mine was a wire in the harness under the tank grounding out on the frame. right on the bolt where the back of the tank slides under. previous owner had a splice job going on in there and even tho it was taped up the frame still has enough current to short it out. I taped the hell out of it and its been good to go since.
Old 20th June 2011
jharback's Avatar
When you have time get some heat shrink tubing. Works like a charm.
