Last Post: Crosshairs
0 Need advice
Last Post: Krjrcustom1
Last Post: 60weight
0 New From CA
Last Post: 60weight
0 FNG from OKC
Last Post: GeoK
0 Oil Hose replacement help.
Last Post: McQueen
0 Shotgun Porn
Last Post: GeoK
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 New in NM
Last Post: GeoK
Last Post: bfarrell
Old 19th June 2011
digger06 digger06 is offline
Sportster/Buell Year: 88
Other Motorcycle Model: zrx1200
digger06 is an unknown quantity at this point
Default wiring diagram
only had the bike a few days, appears its been wired really badly,
i lost lights last night, fixed that, but on the way home its lost its spark,
is there an online wiring diagram anywhere, im completely lost with this now,,
i dont want to let myself get put off with these problems, im gonna rewire it, properly
any help appreciated,
its an 88 xlh
Old 19th June 2011
shaymus's Avatar
shaymus shaymus is offline
Sportster/Buell Model: Sportster 1200 .030
Sportster/Buell Year: 1987
shaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of light
Here is a basic diagram that I got from these forums:
Old 19th June 2011
rottenralph's Avatar
What year bike?
Old 19th June 2011
its a 1988, theres a live that becomes live when the kill switch is in the start position, but it doesnt go anywhere, i presume thats the problem?must av pulled out of a taped wire,
its white but i cant see where it goes,
will it be the live wire to the coils?
Old 19th June 2011
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
The white wire comes out of the run/stop switch and carries power to your starter button and to your coil.
Cosmo
Old 19th June 2011
the power is there to the starter, it turns over, so i presume this can be put straight to one side of the coil,
but which side? how do i tell, ?
its all new to me im afraid
Old 19th June 2011
You should have a white wire coming out of the coil don't you? There are two wires coming out of the coil that go to the ignition module (blue) and the tach (purple...if you have a tach). The other post should have two white wires going to it. That is what my schematic shows....would have to see it in person.
Old 20th June 2011
many thanks cosmo,,,,
it linked in down the loom, it had been taped up and come loose, wrong colour too
anyway, iv put it all ok ,soldered connections ,,,so alls well, for now
Old 20th June 2011
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Make sure you get some heat shrink tubing to cover those connections. If your using tape you'll be re-doing it in another year or so. Do it right once.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 20th June 2011
all done, heat shrink, solder and connections are free from work,
when the boss aint there
