0 Brake Squeek
Last Post: Tucsonmax1
Last Post: cazz1000
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Not charging issue!
0 1977 Bright Blue
Last Post: robistro
Last Post: T^2
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
brake pressure, brakes, passenger
Old 20th June 2011
matridge's Avatar
matridge matridge is offline
Sportster/Buell Model: 883c
matridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura aboutmatridge has a spectacular aura about
Default brakes lose pressure only with passenger
so apperently every single time i have a passenger, my rear brakes lose all pressure. not immediatly but after a few miles of stop and go traffic. when i ride myself the brakes rebuild pressure by themselves. i took apart the master cylinder and didnt find a ripped cup like others have had. i brought it to an indy and them check it out but it was working that day so they said it was fine. i took the caliper apart also and cleaned and lubed it up. bled lines and worked like they are supposed to, then ride with a passenger and they lose pressure again. its never happened when im riding solo. the easy fix is to not ride a passenger, but seriously what the hell is going on. too much weight, me and my ol lady arent that fat. lol
Old 21st June 2011
wedge's Avatar
wedge wedge is offline
Describe "loose pressure". Do you mean the brake pedal goes all the way to the bottom and nothing?
Old 21st June 2011
matridge's Avatar
brake goes all the way down with absolutly no braking power. not weak break, none at all.
Old 21st June 2011
ghostlycadillac ghostlycadillac is offline
ghostlycadillac will become famous soon enoughghostlycadillac will become famous soon enoughghostlycadillac will become famous soon enoughghostlycadillac will become famous soon enoughghostlycadillac will become famous soon enoughghostlycadillac will become famous soon enough
Losing pressure? Or brake fade?
Old 21st June 2011
matridge's Avatar
then overnight, pressure builds back up on its own.
Old 21st June 2011
matridge's Avatar
im not sure what brake fade is
but brake pedal goes all the way down with no response at all
Old 21st June 2011
alank alank is offline
Other Motorcycle Model: V-twin Schwinn Chopper
alank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nice
I'd get a new master cyl. rebuild kit and put in there.
Old 21st June 2011
matridge's Avatar
alank, i am already planing on it, i just wonder if anyone has ever heard of this. it has happened 4 or 5 times. everytime i have a passenger. never when i ride alone. and im riding everyday.
Old 21st June 2011
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
What fluid are you running DOT 4 or DOT 5? Might be that the extra braking effort is boiling the fluid - and that will cause fade. DOT 5 has a higher boiling point than DOT 4 and mixing DOT 4 and 5 will cause all kinds of issues.
SEMJPM
Old 21st June 2011
asasial's Avatar
asasial asasial is offline
Sportster/Buell Model: 1200c 1980 chopped frame
Sportster/Buell Model #2: Ironhead chopper
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Nightster GF's Bike
Other Motorcycle Year: 2008
asasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to all
i had a master cylinder once that i had to tap the brake real fast before i pushed it, if i didn't the petal would go all the way down with no braking power. disassembled it several times, found nothing wrong with it put a kit in and still never fixed it. not much fun when your running rear brake only. I replace/upgraded to a better one.
1979 Ironhead Chopper aka Home Wrecker
1995 1200 on a modified 1980 frame rigid mount swingarm
2008 Nightster GF's bike
Why buy parts, when you can pick up some tools and make something way cooler?
