0 Curious as to what I actually have
0 '89 Sportster 1200 Chopper
0 Engine dies when choke off
0 rpm jump pulling in clutch
0 Value of a Boattail?
0 New to Harley
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
0 79 ironhead
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 THE Trainspotting Thread
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
Last Post: tvon
Old 28th June 2011
mclaggan123's Avatar
mclaggan123 mclaggan123 is offline
Sportster/Buell Model: 1200
mclaggan123 is an unknown quantity at this point
Default exhaust help
I have a 2003 1200 custom and its my first bike. It came with a k&n air filter and vance & hines straight shots with slash tips. the previous owner didnt rejet so i took care of that. The pipes are scratched up a little and my bike doesnt seem to have the power my wifes 2000 1200 has with hers having SE2 slip ons. What would you fine folks say is the best exhaust for performance? I would like more get up and go. It seems like a dog. I had the jets professionally installed and the carb tuned. Any help will be appreciated. Also if you dont mind post some pics of the exhaust you reccomend. Thanks very much.
Old 28th June 2011
tat2cj's Avatar
tat2cj tat2cj is offline
tat2cj is a glorious beacon of lighttat2cj is a glorious beacon of lighttat2cj is a glorious beacon of lighttat2cj is a glorious beacon of lighttat2cj is a glorious beacon of lighttat2cj is a glorious beacon of lighttat2cj is a glorious beacon of lighttat2cj is a glorious beacon of lighttat2cj is a glorious beacon of lighttat2cj is a glorious beacon of lighttat2cj is a glorious beacon of light
the V&H short shots are the worst performance exhaust out there or so i've read on here. if you want more get up and go most will tell you get a good 2n1.. hope this helps
So if someone throws a rock and knocks me off my donkey does that mean I'm stoned off my a$$......
When seconds count, the Police are always minutes away.!!!!!!!
Support Concealed Carry Laws!!!!!!
Old 28th June 2011
SuicideCharley's Avatar
SuicideCharley SuicideCharley is offline
Bike Builder
SuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to all
Thunderheader, but I'm biased
What type of ac do you have? What are you currenlty jetted at if I may ask?
Old 28th June 2011
Don Burton's Avatar
I see that you have Vance & Hines Straight Shots and not Short Shots as the poster mistakenly referred to in post #2 above. I can tell you that Straight Shots do leave some lower and midrange power on the table even over stock mufflers. I run Gronk Modded mufflers but if you want louder, Cycle Shacks are supposed to be the best bang for the buck. You don't need to spend the money on a 2:1 exhaust unless you want to.
Old 28th June 2011
I have STRAIGHT SHOTS and a K&N ac. Im not sure what its jetted to. I had chix cycles in virginia beach install the jets. It runs great but the power is lacking compared to the wifes 1200.
Old 28th June 2011
shotgun46's Avatar
mclaggan123 have you tried to put it on a Dyno ? to see the real picture on how it's tuned ! that might help you dial it in Better !
Old 28th June 2011
the shop did dyno it and tune it right for my setup but i can tell the differance between mine and the wifes. she has the stock ac and se2 slipons and mine lags compaired to hers. it did improve alot with the rejet and tune. but i think a differant exhaust would make it even better. thanks again
Old 29th June 2011
Motorhead52's Avatar
Motorhead52 Motorhead52 is offline
Sportster/Buell Model: 883 sportster
Other Motorcycle Model: BMW
Other Motorcycle Year: 1973
Motorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura about
stock headers and slip on's Rock
Best bang for the buck....... I can pace a 90# woman on a 671 Triumph with my Weisco
1200 with Drag pipes cut stock like stock headers with Screaming Eagles Type 1 tapers
44 pilot 1.75 turns out
180 main
Nook needle
A.N.Big Sucker with a K&N filter and early 6" bell cover
Oil cooler, oil temp is around 210 on a 90 degree day
