0 z bars
Last Post: lucifer_mr2
Last Post: big andy
0 Brake Squeek
Last Post: Tucsonmax1
0 Won't rev past 1200
0 Value of a Boattail?
Last Post: Monte03
Last Post: Jowniofownio
0 Not charging issue!
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Mikuni HSR42
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Old 30th June 2011
trtinney trtinney is offline
Sportster/Buell Year: 1981
trtinney is an unknown quantity at this point
Default Hardtail questions
I know a lot of people disagree with rigids, but I'll start off by saying, I'm only 21, so I can plead young and stupid. Now on to the question.
I have an 81 that I put a new front end on, its a wide-glide about 4 inches over stock, and I'm looking to get a rigid with some rake and stretch to deal with this. I built my brother a 77, which came with an already rigid frame that had around 2 inches of stretch and about 10 degree of rake, and he's running my stock narrow-glide, and needs stock rake and stretch to bring it in.
I'm hoping to figure out a way to hardtail my stock 81 frame and swap with his bike, but I'm not sure how to work out running the drum brake on his 77. I'm not sure if there is a way to weld on an older style drum hardtail kit on to my later model disc frame, so any suggestions would be greatly appreciated!
Old 30th June 2011
hasselme0 hasselme0 is offline
Sportster/Buell Model: xls roadster rigid
Sportster/Buell Year: 1979
hasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura about
get in contact with Kansas Kustoms or Ledsleds they can hook you up. I ride a rigid and Im an old fart.
Old 30th June 2011
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to all
I made my own. I'm an old fart too. (pretty old not tooo old)
I put a disk on the back to help with stopping, hide it under my bags. Easy upgrade.
you can see pics in this thread:
http://xlforum.net/forums/s....php?t=1144545
Scott
'61 'CH
'60 'CH
Old 2nd July 2011
I don't have a lot of cash to throw around, but I'm not afraid of a little fabrication. And I would try and run a disc on the 77 but he's using factory mag wheels.
Old 2nd July 2011
An 81 has the triangulated frame and is not going to have that "look" if hardtailed.
Old 2nd July 2011
asasial's Avatar
asasial asasial is offline
Sportster/Buell Model: 1200c 1980 chopped frame
Sportster/Buell Model #2: Ironhead chopper
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Nightster GF's Bike
Other Motorcycle Year: 2008
asasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to all
some companies make weld on hard tails specifically for the 79-81 frame. you have to pretty much cut the entire back half of the frame off to do one.
1979 Ironhead Chopper aka Home Wrecker
1995 1200 on a modified 1980 frame rigid mount swingarm
2008 Nightster GF's bike
Why buy parts, when you can pick up some tools and make something way cooler?
Old 2nd July 2011
asasial's Avatar
IF you are a decent welder/fabricator i don't see it being to hard to adapt a drum brake hardtail to fit an 81 frame.
but then again i've been know to do all kinda crazy s#!t, like shoving a 95 engine into a highly modified 80 frame with a rigid mounted swing arm, no struts or anything at the rear of the swingarm for support. .
