Last Post: kaveebee
7 Long Road Trip advice
Last Post: jammantoo
0 Feeling in trouble.
Last Post: moparnut72
0 Back in Sporty Land
0 Diagnostic help
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
Last Post: seanq2208
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
performance, reliability, screaming eagle
Old 12th August 2011
Airbozo's Avatar
Airbozo Airbozo is offline
Sportster/Buell Model #2: S3T Thunderbolt
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XB12R
Other Motorcycle Year: 2009
Airbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond repute
60k on my 1200 now 1500, (89" stroker).
I have about 10k on it since the engine rebuild and no issues. I expect about 60k more, but I am an optimist and never dealt with this sort of HP engine (96hp, 101 torque) in a motorcycle before.
"...Dumb all over, A little ugly on the side... "...Frank Zappa...
Old 13th August 2011
boxcardenny boxcardenny is offline
Sportster/Buell Model: xl 1200r
Other Motorcycle Model: cb 750 honda
Other Motorcycle Year: 1974
boxcardenny is a jewel in the roughboxcardenny is a jewel in the roughboxcardenny is a jewel in the roughboxcardenny is a jewel in the roughboxcardenny is a jewel in the roughboxcardenny is a jewel in the roughboxcardenny is a jewel in the roughboxcardenny is a jewel in the roughboxcardenny is a jewel in the roughboxcardenny is a jewel in the roughboxcardenny is a jewel in the rough
i got a 2004-1200r sporster taxs paid, heavey breather, se slip ons.i got 18k and sum change on the clock. i started to here a metal on metal sound only in 1st gear.starting out and gearing down.igo to the hd shop and they took me right in took off the side covers on the motor both sides,and we saw on the right side metal shaveing coming out were it should not be,got in to the trany and they tell me that 1st gear was not getting oil? what de.how can the outher 4 gears git oil and not 1st? the tects at the dealer all said they never herd or saw this on a sport,burl or how you spell it they saw but never on a sportster.i was given a phone no to call hd custemer service.i should have talked to the dog that i dont have anymore,i am not a cert mech or work for hd so no info on a bad part witch 4 indy told me thats what had to have happen. when i get dun with the bill i will post it and sit back and see who thinks what.i will not bad mouth the dealer they had my bike the last 4yrs doing the 5000 check up oil and the rest of it,i keep mt bike there in the winter.i will say this the drain plug on the trany i took out by hand! it was not lecken,and i was down 3 fours of a qourt of oil.they had sum changes at the dealer wit tects and service mang,i will look at all bolts before riding away.will this happen again after 15k or 18k i dont no,this i no it was not cheep to fix.1,736 bucks after i put 3,000 in chrome on it.so no turning back.i am 54 and on ssd so i only get so much a month,i took a hell of a hit on this,i hope it dont happen again,any body with advice or did it happen to you or a brother plese gimmy a yell,tanks
Crosshairs's Avatar
Crosshairs Crosshairs is offline
Sportster/Buell Model: Its Black and shiny
Crosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond repute
If the trans was down 3/4 of a quart, that's likely what caused your problems....it only holds a quart total, so you had pretty much no oil in there .
If they are the ones who serviced it, I would want to know where the oil went......
motorend's Avatar
motorend motorend is offline
Senior Master Bike Builder
Sportster/Buell Model: XL1200N (Sold)
Other Motorcycle Model: FXDL
Other Motorcycle Year: 2014
motorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud of
Originally Posted by crosshairs View Post
if the trans was down 3/4 of a quart, that's likely what caused your problems....it only holds a quart total, so you had pretty much no oil in there .
If they are the ones who serviced it, i would want to know where the oil went......
+1
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
I got 28K out of the stock engine. Tore it down after the bottom end failed. Upon inspection, there were multiple problems; exhaust valves burnt and pitted, piston carbon was extreme, valve stems and guides galled, cams excessively worn from bits of steel in oil.
Rebuilt with performance parts. No problems yet. Dan (NRHS) was extremely helpful!!
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Well I'm soon headed for failure then, my bike has well over 30 k on it and it runs stronger than the day I bought it with stage 1 setup..
yet I have a bud with a 1994 1200 at last check he had over 85k on it and rides it everywhere on camping road trips up and down between virginia and GA..told me he's only replaced a few gaskets and the valve seals..
Old 14th August 2011
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
My cylinders @ 20,000 miles still had most of the crosshatching....and no scuffing. I ride this baby relatively brisk..........most of the time!
Stuff: YES
goblin_dust's Avatar
goblin_dust goblin_dust is offline
Sportster/Buell Model #2: XR1200
goblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to beholdgoblin_dust is a splendid one to behold
I should probably start another whining thread about the stealers.
It's a long story but this is what happened.
Sometime ago I took my bike to dyno for tuning, it came back with pretty bad results. Somebody here on forum suggested to run crank pressure test, which I did. Front cylinder showed 150psi while the rear 180... Seemed like a problem right then. I added some oil into the cylinder and ran the test again. Pressure did not increase that much, thus it had got be a problem with the valves or so I thought.
I am not all that mechanical, so I took it to the dealer, where I pointed out the service guy on the problem and have them check where I am loosing the pressure.
Couple of days later they come back and tell me the cylinders are worn I have to replace them and pistons too. I said okay, only asked them to check out the valves anyway and run the crank pressure test once they finished. Almost three weeks go by (because they needed to order new parts and they took time) and they call me to come and pick it up.
So, I am there all excited that my problems are over, talked to the service guy and the mechanic who worked on that why would they think cylinders went bad only after 30K miles. They told me of forged pistons, that they wear off the pistons more quickly and it's not unusual what so ever. Okay, I thought, fair enough, it was my choice to put performance parts in it and I have to pay now. I also specifically asked what was they pressure now, the mechanic goes all that "well, i dont remember i wrote it down somewhere, but it's good now". I went ahead and asked what's the psi deviation now, the mechanic told me that it was about 5-6psi.
Okay, I was satisfied with the answered, paid almost $1500 bill and rode home. The bike did not feel any different from before, but I figured it was because I was still breaking it in and did not rev more than 3500rpm.
Tell you the truth I did not test the pressure same night. I rode it next day, breaking it in and the following night I finally decided to do the test.
Imagine how stunned I was when it again showed 150psi on the front and 180 on the rear.
All boiling on the inside I took the bike back to the dealer next morning, which was yesterday.
They took it back put it on the stand and ran the test with me present. So, they run the test on the front jag and it shows a little less than 150. The same mechanic starts explaining to me that 150 is very much what it should be. I said okay, now run the test on the rear. So, he did and it showed 200psi. This time the guy went all defensive, started telling that it was impossible result, that no bike can run with 200psi of crank pressure. Then he made a theory that may be the push rod extends as it's getting hot and keeps valves open, he also made some other theories not worth repeating. At the end he told me the had no clue what's going on or where the problem is, that he would need more time to look at it, which he does not have. And if I brought this bike later in autumn they would have more time to look deeper.
My issue with those guys is not that they made me pay for new parts and expensive work that did not fix the problem, I understand it was more of trial and error type of thing. What I am really pissed of about is that that mechanic was not straight with me, just plain dishonest. He did not run the test after finished the work and lied about it.
I understand some problems may be less obvious than others, mistakes happen too, but I am patient and ready to pay the bill, what I can stand is somebody lying in my face.
So, 30K lifetime for performance engine is just a pile of bull. The guy was just trying and find an excuse for his own incompetence.
I still have the old jags, anybody interested?
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
More of a trial and error thing is not an excuse. This is why you diagnose problems. He did not diagnose the problem and replaced parts that were good. You had to pay the bill and now he doesn't have time to look at your bike after all that. That is bullshit. He should be fixing the actual problem this time for free.
2005 XL1200C
Those who trade liberty for security have neither.
LuxBlue's Avatar
LuxBlue LuxBlue is offline
30k is nothing! Now speedo problems....that's another story.
