Last Post: cazz1000
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Not charging issue!
0 1977 Bright Blue
Last Post: robistro
Last Post: T^2
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
Last Post: 883openpipes
Old 13th August 2011
turkishxl883's Avatar
turkishxl883 turkishxl883 is offline
Sportster/Buell Model: xl883l
Sportster/Buell Model #2: 2008
turkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to all
Default now the front brake noise :)
okey here is my problem sometimes brakes giving noise like howling and i can fell it in my handlebar too.But just only one spot when the pads passed i can hear and feel the noise but sometimes i dont feel or hear at all.What can it be?
IS it my pads worn or my disc?Or the wheel bearings?
Sorry for the bad english i hope you understand it.
Evil_Seven's Avatar
Evil_Seven Evil_Seven is offline
Evil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of lightEvil_Seven is a glorious beacon of light
Maybe it's payback for slashing those truck tires...
http://xlforum.net/forums/s....php?t=1157394
Aloha Snackbar
its a curse my sporty is damned
Old 17th August 2011
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
You can usually see the pads if you get down close and look. If they are under about 1,1-1/2mm or so thick on both sides......I'd replace them for sure. Not hard to do.
Stuff: YES
Flame__'s Avatar
Flame__ Flame__ is offline
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2000
Jack up the front of your bike, eyeball it from the front while spinning it by hand. Maybe you can narrow things down from there.
Knees in the breeze.
Gamertag, PS4: Bikerdude__
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Could be your pads are glazed. A little sanding would fix that.
i will look for it this weekend this sporty is like my girlfriend always need attention
DG_Sportster's Avatar
DG_Sportster DG_Sportster is offline
Sportster/Buell Model: 1200 Sportster C
DG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to behold
If the pads are OK, try cleaning the rotors with some brake clean and maybe a scotch-brite pad.
The water-logged OEM starter/system relay on 2007-2009 Sportsters is a OMRON G8H-UA-007401, but this can be crossed over to some automotive apps: Borg Warner R3154, Gp Sorenson 41-5154, Niehoff RL 35381 are examples. Good luck!
