0 Ironheads
0 Salutations y'all
Last Post: Fridge
Last Post: Vohnsen
0 67 Sportster build
0 There’s shade tree brakes; then there’s the dark side of shade tree
Last Post: sdsbassist
Last Post: Grumpy-Biker
0 no rear brake light
Last Post: geoff
Last Post: goblin_dust
Old 14th August 2011
garykohl2's Avatar
garykohl2 garykohl2 is offline
Sportster/Buell Model: 883
garykohl2 is an unknown quantity at this point
Default Strange turn signal problem
Hey guys! I just got my 02 883 and it has and issue with the left turn signal (its been this way since I got it)
If the bike is just on but not running the left turn signal works fine. Once you start the bike it still works if the bike is just idleing. Once you give it some throttle though it freezes in the "high" light. So if I'm riding at any speed and go to use my left turn signal it just comes on bright and stays that way....no flashing at all. Any ideas?
Thanks guys
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Which one stays on bright?...front or rear?...or do they both do the same thing? When there isn't enough amps drawn from the turn signal module (due to a bulb being burnt out or bad ground) then the turn signal module doesn't flash.
My first thought is bad ground. Remove your bulbs and make sure there isn't a lot of corrosion in the sockets.
Cosmo
garykohl2's Avatar
It is the front and rear....they both do it. I will pull the bulbs and check them tomorrow. Thanks
