0 2016 48 Hesitating
Last Post: 201648Rider
Last Post: Jheitt
0 New member in MD
Last Post: Veeflys
0 Primary Oil INSANITY!
0 Newbie CV rebuild
Last Post: Matt Black
0 Ei
Last Post: cazz1000
0 Decman's Birtday
0 Turn signals
Last Post: bockstroker
Last Post: r4fthrs
0 Oil??
Old 6th December 2007
mark61 mark61 is offline
mark61 is an unknown quantity at this point
Default 1200s a little bit lower please.
i just got a 1997 1200s at a good price. the problem is i'm "verticaly challenged"! now i have read about the "s" models great suspension and some might think that changeing it's forks and shocks is stupid but i never had any thought to do some knee dragging on this thing anyway! i will eventualy do more of a bobber project out of it in the future. i would like to keep the dual disk up front but want to give it a lower look and feel for my height. i'm all for keeping the stock rear shocks but i have noticed that any "lowering" kit out there says it can not be used on the 1200s model. i need some help with this. it looks like i might have to buy a different front end and loose the dual disk set up or try to find a kit to lower my 1200s 's forks. thanks for your help!
capttawes's Avatar
capttawes capttawes is offline
capttawes is on a distinguished roadcapttawes is on a distinguished roadcapttawes is on a distinguished roadcapttawes is on a distinguished road
Just need shorter rear shocks and lowering kit (springs) for the front.
You can likely get a good price selling the 1200S shocks as they're popular.
Progressive is the most popular and cheapest solution for suspension.
I did not see the 1200S listed on their site for shorter shocks and springs so you might give them a call 714.523.8700 or email info@progressivesuspension.com and ask for suggestions.
Matt
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
You have a "S" and a lot of people would gladly trade for your parts but I don't think you should give them up. Don't be in a big hurry to down grade your suspension, you may get use to the height. Taking off the dual brakes is a no-no. How about a lower seat? You could pick up 2". I'm 5' 6" and have the 13 ½" shocks, stock front end and a Reach seat. No problem flat footing for me.
jrossty's Avatar
jrossty jrossty is offline
jrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nice
When I first got my 'S' I was uncomfortable, barely getting my feet flat. & I'm 5/8. But I rode it awhile, and got used to how it felt and handled. Then I found out what I really had when I compared to some other sportsters, and found this site. My suggestion is to ride it maybe a little longer, and then make a decision after another 400-500 miles. Just my 0.02 cents though.
James
aka "Chief James" of the Heavy Horses MC
"Whatever doesn't kill you, makes you stronger"
XLXR's Avatar
XLXR XLXR is online now
How much do you weigh? How much lower do you really need to go to get your feet on the ground?
I would be a lot easier to lower the seat by replacing the foam, or buying a new seat.
You might be able to set the shocks to the lowest preload setting, reduce fork preload, and move the forks up in the triple trees to gain an extra inch or two. This may change how the bike handles, so take it easy on the first test ride.
melcheld's Avatar
melcheld melcheld is offline
melcheld has disabled reputation
1200S's have adjustable catridge forks up front. You can't swap springs out on them. The best you could do is move the fork legs up in the trees by an inch or so and buy shorter shocks for the rear.
However, as a previous post said, changing the seat will make a huge difference. I have the LePera barebones seat and it dropped the seat height by 1.5-2" below the stock seat height. I'd go that route first. You can pick that seat up from CyborgCycles for about $125- much cheaper than any suspension work. Plus, you get to keep the great 1200S suspension.
Cheers,
Luke
Now if I have suspicion a felony's been committed, I can just walk right in here anytime I feel like it because I've got this badge, I got this gun, and I got the love of Jesus right here in my pretty, green eyes.
i was told that the fork legs could not be pushed up because they had a camphered edge that stops at the top tripple tree top. in fact the guy at the bike shop showed me a set of fork tubes with the top bolt on it. could he be mistakenly be talking about "big twin" forks? i thought all the narrow glide forks where pretty much the same?
Bob F's Avatar
What he said!!!
paulskav paulskav is offline
Sportster/Buell Model: xl883/1250
paulskav is on a distinguished roadpaulskav is on a distinguished roadpaulskav is on a distinguished road
+1 on changing the seat first. Stock seat sux and needs to be thrown out anyway, IMO. I got a seat that put me closer to my handlebars and also dropped my "seat height" by an 1".
Kit1 Kit1 is offline
Sportster/Buell Model: 1200 Sportster Sport
Kit1 is an unknown quantity at this point
I put a White Bros lowering kit on my S no problem. Lowered the seat height about an inch and a half.Forks can be put up through the top tree also.
