Last Post: Crosshairs
0 Need advice
Last Post: Krjrcustom1
Last Post: 60weight
0 New From CA
Last Post: 60weight
0 FNG from OKC
Last Post: GeoK
0 Oil Hose replacement help.
Last Post: McQueen
0 Shotgun Porn
Last Post: GeoK
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 New in NM
Last Post: GeoK
Last Post: bfarrell
Old 7th December 2007
Yaron2 Yaron2 is offline
Yaron2 is an unknown quantity at this point
Question swapping forward controls for mid controls
I have searched high and low but cannot find any PICTURES WITH INSTRUCTIONS for removing the forward controls from my 05' Sportster Custom and replacing them with mid controls. Can anyone point me in the right direction??
punkmxcn punkmxcn is offline
Sportster/Buell Model: xl
punkmxcn has disabled reputation
they usually come with instructions
"LOUD, PROUD, AND PUNK!"
there are instructions for swapping mid controls TO forward controls .... I want to change my forward controls to mid controls! My bike came stock with forward controls .... anyone??
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
The parts catalog shows the placement of these parts very clearly. Everyone should have a service and parts manual. My 2¢
deethe's Avatar
deethe deethe is offline
Sportster/Buell Model: XL883R
deethe is an unknown quantity at this point
start from the back and work forward, disconnect the rod at rear brake piston then two bolts holding pegs; same for shifter: rod at tranny then footpeg bracket, then just disassemble forward to install on mid brackets. sorta the reverse of mid to forward. i have instructions for mid to forward and could try to scan it to you (fax would be easier) if i can figure how to upload images here.
2006 XL883R- Mirage Orange:
Rinehart slip-ons, Thermo-tec wrapped headers, Crossroads Perfomance Air Box w/ Devonator, Dynojetted CV carb, Progressive 440 rears & Progressive Fork Springs, Corbin Hollywood seat, Custom Classic MB1400 Saddlebags.
oakies's Avatar
oakies oakies is offline
Sportster/Buell Model: Dyna Wide Glide
Sportster/Buell Model #2: Roadster
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Ultra Classic
Other Motorcycle Year: 2011
oakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura aboutoakies has a spectacular aura about
If you have all the parts you need...Its really self explanatory
04 Roadster
06 Dyna Wide Glide
Everyone know that Silver is the fastest
Phillthy's Avatar
Phillthy Phillthy is offline
Sportster/Buell Model: 1200R+
Phillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura about
Do what I did and take the controls off the forward ones and mount back and use the pegs as highway pegs. If you ever want them back on it's an easy process.
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
It's all in the service manual.
Folkie
South East England Riders
Old 8th December 2007
ebikerman's Avatar
ebikerman ebikerman is offline
Other Motorcycle Model: Cushman Eagle
Other Motorcycle Year: 1962
ebikerman is an unknown quantity at this point
Default Forward to mid controls
Changing from your stock forwards to mid controls is probably not the usual direction bikers go. However, I did just what you are talking about to my 06 Custom. It is easy except that there are no kits for this conversion. My dealer said the parts if purchased for this change would cost about $1000. You might do as I did and go to ebay and search for mid controls that have been removed when changing to forwards. I found a set of mids, brand new, removed from a nightster for $75. As far as installation goes, you will not need pictures, just look for the existing bracket holes in your frame (may have plastic plugs in them). Remove all the forward stuff and use same hardware to install mids. Some plastic cable holders may hang loose when the front pegs are removed. Just use some more same size bolts to fasten them down again.The worst part of this job is getting to the rear brake rod mounting screw. I had to have a friend pull on the exhaust pipe to move it out a little so I could get to the screw. You might loosen the exhaust at the head, but we just stretched things a bit and left the exhaust tight. We did remove all other supporting hardware for this pipe. Beware, the screw I am talking about was not an allen screw although it looked like one. It was a star or something which my friend had the proper tool to fit it. Nothing to it. Hope this helps....Dan
Black '06 Sportster 1200 Custom... Fast/Powerful... Stock carb and A/C. Stock mufflers, 13 spoke cast chrome wheels (front and rear), varius chrome and Hot Toppers, Black horn and A/C ham can, Flared rear fender, AMP Research EZ Pull clutch device that really works.
Believe it or not, there is life beyond Harley-Davidson...Plan for it. May God bless you with eternal life through His Son Jesus.
Old 9th December 2007
Folkie's Avatar
Brass Nut
$1,000? That's crazy. I've just priced up the parts that you'd need. Assuming that you reused some of the screws, it comes to $220.34. That's at Zanotti; it'd be a little more at the dealer.
