Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Lighting
0 Value of a Boattail?
Last Post: valvebeater
Last Post: jammantoo
Last Post: lugster
0 Viking bags??
Last Post: cotton1
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 2001 883 'customizing' log
Last Post: cotton1
0 rpm jump pulling in clutch
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: jordan1200
Last Post: Racepres
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
Last Post: gravydog
5 Am I looking for Trouble ?
Old 4th September 2011
Gojira's Avatar
Gojira Gojira is offline
Bike Builder
Sportster/Buell Model: 883r
Other Motorcycle Model: cb750
Other Motorcycle Year: 1974
Gojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the rough
Default turn signal issues
ok heres the problem,with the ignition on and engine off everything works fine i.e. right and left turns flash and hazzards flash,if i start the bike then only the left signal will flash and the hazzards work but the right signal just gets bright and does not flash any input would be appreciated....
Old 5th September 2011
Gojira's Avatar
Bike Builder
bump,cosmo where you at....lol
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Sorry Go....went to pick up a new jeep and was driving it home
Go, does both the front and rear right signals just get bright? Also...what does it do if the ignition is on and the bike isn't running?
Typically these is a bad ground issue if both lights are lighting up as the TSM is not seeing enough current drawn from it so it doesn't make the signals flash.
Just out of curosity....pull the fuse for your lights and see if it does the same thing with the bike running and / or the ignition "on".
Cosmo
Gojira's Avatar
Bike Builder
yes,well the rear comes on and the front gets bright as the rears are not running lights,with the ignition on engine off everything works fine its only when the engine is running that the right side dosnt flash,the hazzards will flash with the engine running
I would start by pulling the bulbs our make sure there isn't any corrosion in the sockets. Then I would start checking the grounds and make sure everything is tight...with a wrench...not just wiggled by hand. Somewhere in the front or back you have an open condition in the ground wire since you are getting the lights to actually light up. Thats my $0.02....could be a pain the arse to track down.
If you have a multimeter that could help checking continuity of the ground wires too.
twotoneXLH883C's Avatar
twotoneXLH883C twotoneXLH883C is offline
Sportster/Buell Model: XLH883C
twotoneXLH883C is just really nicetwotoneXLH883C is just really nicetwotoneXLH883C is just really nicetwotoneXLH883C is just really nicetwotoneXLH883C is just really nicetwotoneXLH883C is just really nicetwotoneXLH883C is just really nicetwotoneXLH883C is just really nicetwotoneXLH883C is just really nicetwotoneXLH883C is just really nicetwotoneXLH883C is just really nice
It might be the TSM is faulty too. I had an issue with mine working and it ended up being the TSM that was causing the problem.
Any time I can ride and make it back home on my feet is a good day!
Gojira's Avatar
Bike Builder
well the rear is only one wire and grounded through the housing,the front uses three wires two positives and one ground,i just dont understand how they can work with the engine off but not when running....
That is the typical wiring on most Harley's, rear is a single wire while front are three, rear is a single filament and front is dual filament. But as I said by the sounds of it the TSM could very well be the problem. When I had issues with mine they would sometimes work then as I'm going down the road the TSM would malfunction and the signals wouldn't flash, I checked the bulbs and wires finding nothing wrong, I've also got one of those run/stop/turn modules on my bike but the TSM was where the problem was at, a new TSM and they've worked ever since.
TazzinTroll's Avatar
TazzinTroll TazzinTroll is offline
Sportster/Buell Model: XLR 1200
TazzinTroll is a jewel in the roughTazzinTroll is a jewel in the roughTazzinTroll is a jewel in the roughTazzinTroll is a jewel in the roughTazzinTroll is a jewel in the roughTazzinTroll is a jewel in the roughTazzinTroll is a jewel in the roughTazzinTroll is a jewel in the roughTazzinTroll is a jewel in the roughTazzinTroll is a jewel in the roughTazzinTroll is a jewel in the rough
I have a 04 and my turn signals just started screwing up. My left signal comes on when the key is turned on and the left switch will not turn it off. But if I turn the right on then off the signals will turn off. The right one works fine. I cheched the lights and switchs for shorts and can find any . Now I will check for missing grounds. Maybe I'll just buy a new TSM?
Wreckless and Wild Baby!
