Last Post: Vohnsen
0 Fact or Fiction - HP Claims
0 More of a reintroduction
Last Post: spitfirechopper
0 Cylinder Piston kits
0 Clutch Spring plate poll
Last Post: NZstu
0 Trade Chrome for Black?
0 Bars on C Riser?
0 1967 XLCH stroker project
Last Post: kaveebee
0 crack in head
Last Post: slamtry
Last Post: 45Brit
Last Post: kaveebee
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
Old 26th August 2005
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
Default Dunlop 402 vs. 401 rears
Over the past several years I have had several different Dunlop rear tires on my scoot. I have to admit that I am pretty abbusive to the rear tire because I really like to twist my right wrist Anyway, my 2000 883C came with a D401 130/90-16 on the back and a D402 MH90-21 on the front.
When I got a screw in my rear tire, and was stranded, my local HD dealer replaced the factory D401 with a D402. When I questioned him about it, they claimed it was just a better tire and that all the 'big' bikes come with the 402 stock. I figured he was right. The tires are identical in appearance (tread pattern, side wall, etc). The bike seemed to perform fine with this tire on it, but it just didn't seem to last nearly as long or have the accelerating grip of the stock one.
After that one wore out very quickly and the front was finally ready to replace, I went out on the web to find a good deal. And that I found. I posted a while back int eh good vendors section all the details abotu this tire distributor. In that research, I kept coming across everyone recommending the D401 for the rear, so that is what I ordered and installed not even thinking about what the differneces were between the 401 and 402. Honestly I just figured since the big bikes had the 402 and the Sportster has had the 401, that the 402 much just be capable of handling more weight.
This tire is lasting quite a bit longer again and I haven't changed my riding style at all. So that got me to thinking....what is the REAL difference between the D401 and D402? I am just barely into my research on this, but thought I would pass along the initial findings. The size of the two is different!!!!! Yep, that's right the D402 (REAR) only comes in a MT90 B16 and the D401 is a 130/90 B16.
Translation:
401 = 25.40" diameter, 5.18" width, 12/32" tread depth, 805#@41psi weight capacity.
402 = 25.70" diameter, 5.20" width, 9/32" tread depth, 827#@40psi weight capacity.
As you can see, the 401 comes with deeper tread from day one. AND your speedo will be slightly off with the 402 from the slightly larger diameter.
I'll keep researching and will post whatever I find, but as a word of advice, unless you are really in a pinch, try to make sure that a 401 remains on the back of your scoot.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
XLFREAK XLFREAK is offline
Good info, Shu!
Lucifer Lucifer is offline
Lucifer is an unknown quantity at this point
Thanks Shu, Good research and info!
I never considered a 402 on the Sportster but I was thinking about a set of 591's.
I think they were stock on the 1200S bikes. Anyway we (myself and friends) have purchased tires from Ron Ayres Racing off the web and found prices, freight, and customer service top notch. They offer most popular sizes and tread designs for H-D.
I've got over 10,000 miles on a 401 and it still looks good (deep tread) but I would like to know how the 591's wear. I think they are a softer compound.
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
I was told that the 402 was a longer wear tire with a harder sidewall...
Thanx for this info...I have 401's on front and rear right now...I'll need to replace rubber before the year is out....
I'll be looking forward to seeing anything else you discover....Thanx!
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 4th September 2013
JJOkey01's Avatar
JJOkey01 JJOkey01 is offline
JJOkey01 is an unknown quantity at this point
I have the very same bike and tires and love it. D401 has nice looking tread on the back still and it's getting pretty squared out....I'm looking to replace them. I was considering the 591's but wasn't sure if that would be a better tire for canyon riding. Can easily scrape pegs now, before the tire was worn down, and never felt my bike slide. It's my first bike and I've only been riding for about 5 Months maybe. I like to ride canyons a lot though and haven't for a while just because I need new tires. Any suggestions? I would go for a wider tire like the newer sportsters have but the older bikes down allow it.
