0 headight housing
Last Post: Len PA
Last Post: MatHormell
0 Hope Cove, 20th May 2018
Last Post: Gamble Gold
Last Post: VaFish
0 A Day in the Life...
Last Post: cotton1
Last Post: cotton1
0 Diagnostic help
Last Post: BradX13
Last Post: 83XLX
Last Post: lugster
0 The country store
Last Post: lugster
Last Post: lugster
Last Post: sevenyears of famine
Last Post: lugster
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
Last Post: guitarfish
0 Speedometer Damage
0 new oil lines
Last Post: Screw Loose Dan
0 THE Trainspotting Thread
Last Post: lugster
Last Post: lugster
Last Post: 883openpipes
0 96 xl1200c turn signals help
Old 14th December 2007
Moe47's Avatar
Moe47 Moe47 is offline
Sportster/Buell Model: XL883L
Moe47 is a jewel in the roughMoe47 is a jewel in the roughMoe47 is a jewel in the roughMoe47 is a jewel in the roughMoe47 is a jewel in the roughMoe47 is a jewel in the roughMoe47 is a jewel in the roughMoe47 is a jewel in the roughMoe47 is a jewel in the roughMoe47 is a jewel in the roughMoe47 is a jewel in the rough
Question 4" over fork tubes
Ok, I gave up trying to find a cheaper way to get more travel out of my 08 883L forks. So I am going to stretch things out a bit. I like'm long and low.
I'm going with 4 inch over tubes, progressive damper rods and springs (1/4 inch exposed preload spacer), the air fork mod, 3 degree cups and 3 degree trees. The trail works out to between 4.8 and 5.2, depending whos calculator is used with the 13 inch RK air shocks lowered 1 inch. The wheelbase ends up 3 or 4 inches longer while only raising the seat height around 1 inch and the frame rails should end up level to the ground.
My question is; how much oil am I going to need when I install these tubes?
Would I do the measure from the top thing or go with the one ounce over recommened Whittlebeast theory?
If it is gotta be the trial and error method what would be a good starting point?
Thanks in advance!
black06883 black06883 is offline
Banned
Sportster/Buell Model #2: XLH1000
Sportster/Buell Year #2: 84
black06883 is an unknown quantity at this point
I too would be curious about these questions being answered. I am looking to get tubes that are only 1 to 2 inches longer to compensate to my much longer shocks.
Moved On Moved On is offline
I'm not an expert here... but I very much doubt that getting longer
tubes is going to give you any extra travel. The travel will still be
limited by the ends in the sliders. won't it?
Gazza
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
you got it gazza, only longer sliders will give more travel but they don't make such a thing
"lord of the Night Lite"
thank god for darwin ;)
Banned
LOL well there goes my great idea! That explains why the old dirt bikes had sliders that were so long the axle sat a few inches up from the bottom. Hmmm what to do now?
Xman75's Avatar
Xman75 Xman75 is offline
Sportster/Buell Model: Sportster 1200c
Xman75 is an unknown quantity at this point
why are you trying to get more travel?
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Tubes get longer, the oil level stays the same as wet or dry!!
RTFS
Ride That F'N Sportster!!
snowman's Avatar
snowman snowman is offline
The other thing that's not coming out right in your calculation is the frame rails sitting level on the ground.....
I've just completed this install and MAYBE, if you did a 6* rake at the trees, you might be close to level, but doing 3* in the trees and the cups, 2" over is the level length you want on the tubes...
4" over lifts the rails about 1 1/2" higher and you'll need an 11" jiffystand from a glide or softail...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Banned
Ever ride a bike that has long travel comliant suspension? Gives a great ride. Had an old BMW air head that had long travel set up and thought it would be great on the sporty. But that's just me.
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
If the sliders are the same as the R models. using a longer tube and springs should increase the travel to that of the R model. i think it will work though you may need to change some other parts like the dampers maybe. A parts break down of the two would show any differences.
