Last Post: blindfredy
0 DK's Definitive Ride Report - Some of the Best Scenic Roads Out West - Tons of Photo'
Last Post: spoon
0 first harley- help!!
Last Post: Hellbent_4
Last Post: cantolina
Last Post: mac93
0 oil cooler or not?
Last Post: Jason's Sporty
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Intro from New England
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
0 Head gaskets.
Last Post: sevenyears of famine
Last Post: friday
Last Post: guitarfish
0 oil pouring out on right side
0 Sunday 20th May 2018: Hope Cove
0 new oil lines
Last Post: 69sscamaro
Old 2nd January 2005
Question Engine Support Brackets
The Iron has 3 cruddy chrome engine support brackets at the top:
[1] at the front, with 2 nuts, and a bolt to between the downtubes
[2] middle of the left side, with two nuts
[3] rear of the left side, with two nuts, and a bolt to the frame backbone
I want to remove all of these to clean them up. The big question is: Can i remove all of them together? Or should i do them one at a time.
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
mine has.....
[1] nope ain't got it
[2] attached to under side of top tube between heads
[3] nope ain't got that one eather
guess I can't help you as to how to remove them cause I don't have the same setup
"lord of the Night Lite"
thank god for darwin ;)
HrdlyDangrs's Avatar
HrdlyDangrs HrdlyDangrs is offline
Other Motorcycle Model: Yes
HrdlyDangrs has disabled reputation
I think they changed the motormounts in 79 from the single center mount styles of the early Ironheads to a multi mount. Supposedly I think to help with stopping the breaking of the original mounts and the heads from cracking around the bolt holes and to supply a stronger upper engine mount system.
I can't say for sure, but probably the early single center mounting stile will bolt up...if so you can just eliminate the other mounts. You would have to get an early one to see if its possible. I'll see if I can get out to the garage tonight and get my parts book and manuals. I'll check back later.....Anyone else know?? Hrdly
Old 3rd January 2005
Irondrake77's Avatar
Irondrake77 Irondrake77 is offline
Sportster/Buell Model: had an IRONHEAD XL
Irondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of light
mine's like that I took all the bolts out and I still couldn't get the engine out without removing the rockercovers, so you should be alright.
IronDrake Studios
Lightbulb
I should also mention here that i am planning on painting the engine while it is in the frame. So i want to get as much stuff as possible out of the way. Hence, if i can remove all 3 then that makes the painting easier - less masking.
How to remove them is not a problem. I have a wrench! I suspect that removing all 3 is not a problem - the engine will not fall out. But i thought it would be wise to check with the combined wisdom of all my IronBuddies first.
Similar Threads
Carb Still Won't Idle txsurfer Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 29 16th May 2005 18:06
I've got the engine guard blues vjgkam Sportster Motorcycle Accessories 13 14th May 2005 14:20
Blacking out the engine on a 2000...Part Numbers?? raysheen Sportster Motorcycle General Discussion and Problems 7 11th May 2005 17:06
proper wear in time??? for new rings Kev12012 Sportster Motorcycle Engine Conversions 5 5th April 2005 02:14
S&S recomended break-in stevo Sportster Motorcycle General Discussion and Problems 25 19th February 2005 22:38
