0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
0 1977 Bright Blue
Last Post: ericfreeman
Last Post: jammantoo
Last Post: lugster
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
  #671
Old 24th May 2012
rejeanprimeau's Avatar
Any air bubbles in a pipe or tube restrict the flow of a liquid. By closing the loose fitting, you stop the air entering the gas line.
Old 27th May 2012
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
I spent some time yesterday and today re-jetting my carb and I've got it really close to where it needs to be, but I don't think I'm there yet.
Tomorrow, I'm going to load the new map that Rico sent me and go for another shake down run.
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 27th May 2012
Took me 1 hour to set the lectron on my bike.
The PSI seem more complicated than gran pop.
Do you have to actualy change jet or just adjustment?
Old 27th May 2012
Lenster's Avatar
Yesterday, it took me about an hour and a half to change the needle and the nozzle (the nozzle is the needle jet).
Today I changed only the nozzle which took me about half an hour.
Once you have the internal components close, you use the external adjustments to fine tune it.
Old 27th May 2012
The PSI is definetly more complicated than a Lectron. I'm sure the PSI will give a more precise AFR. With the lectron you get it easy or swear you bought another kind of carburetor, LOL. I was lucky; Kevin, the owner of Lectron got me two needles that just fit perfectly my applications: 94 Petro-Can gas and E85. Take me two minutes to switch needle.
Old 29th May 2012
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
hay len hows the bike working for you gettingher legs under it yet.??
Old 14th June 2012
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
Its probably still snowing up there. Seriously though, any updates?
Old 19th June 2012
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Lenster? Hows that beefed up pig coming?
Old 19th June 2012
aswracing's Avatar
A Million Facts & Figures
Yes, we're waiting here in Sandpoint. Dyno'ed an RC51 the other day. He made 114.4hp. I think you'll pound him I want that Sportster! Bring me the Sportster!
Click Here to Contact Me
Old 19th June 2012
Lenster's Avatar
Oh it has legs! I think they could be longer though with more tuning.
The Snow did stop. Unfortunately, it turned to rain! It seems that if it's not raining, I'm working or taking my kid to soccer or doing yardwork or planning our renovation or working on my "honey-do" list.
I thought it was going good, then one day after filling up with gas I noticed that there was gas pouring out all over my HOT engine. That really freaked me out. The gas line had come off of the fuel filter. After I got that fixed, my jetting was all messed up and the bike was running super rich - back to square one on the jetting. IF the weather clears up and I'm not busy I'm going to get the jetting as close as I can with the parts I've got. I've talked to PSI and I may need to do some customization of the slide to lean out a VERY rich condition just off idle. Time will tell - I don't want to go grinding on the slide until I'm sure jetting is not the cause. I can't see reversion being the culprit because of how rich it goes just off idle (less than 10:1 from a 14:1 idle).
Still working on this too. I talked to one of my co-workers who has a condo on Lake Pend Oreille and she gave me the name and number of another person who may have a place for rent during one of the last two weeks of August. Don't write me off yet! I REALLY want my bike to get into your shop.......
