0 Cartridge Conversion?
0 How do you upshift?
Last Post: Sprtstr1200s
0 Photo Gallery for XL Forum Team Members!
0 This Week in my Shop
0 48 Handling
Last Post: Thyratron
Last Post: squekster
0 Error B2116 & 2117
Last Post: tester
5 To Hone Jugs if replace Piston Rings?
Last Post: groovemeisterus
0 79 starter housing torque values
0 Oil line routing on an 80
clutch, mikuni
Old 29th October 2011
MegaDON MegaDON is offline
Sportster/Buell Model: 1973 Ironhead
Other Motorcycle Model: 00' Kawasaki ZX-7R
Other Motorcycle Year: 76
MegaDON has a spectacular aura aboutMegaDON has a spectacular aura aboutMegaDON has a spectacular aura aboutMegaDON has a spectacular aura aboutMegaDON has a spectacular aura aboutMegaDON has a spectacular aura aboutMegaDON has a spectacular aura aboutMegaDON has a spectacular aura about
Thanks Piniongear,
I will take that into consideration. I will mess around with it this weekend. I have a set of removable baffels im going to install first, Reading around, someone mentioned that the straight pipes might need more back pressure, if those dont work, ill move on to the carb.
I will post my results when I can.
piniongear's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: FXDL
OK, let's see what happens.
The baffles are a good thing to have but I do not know if I agree that they are needed for proper 'back pressure'.
A 40 inch long straight pipe gives an ironhead all the back pressure necessary to run strong.
Believe me, I have ridden many an ironhead with unbaffled straight pipes in my time and never had problems..... other than with the Lawman.
.pg
