0 More of a reintroduction
Last Post: k9unitb
Last Post: 45Brit
0 crack in head
Last Post: slamtry
0 Clutch Spring plate poll
Last Post: NZstu
Last Post: 45Brit
Last Post: kaveebee
0 Cylinder Piston kits
0 Bars on C Riser?
Last Post: mattjs666
0 1967 XLCH stroker project
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
0 Fact or Fiction - HP Claims
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
Last Post: kaveebee
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The White Bike is the Right Bike Thread.
Last Post: if6was9
Last Post: Slidesquad24
Old 31st October 2011
DK Custom's Avatar
Sportster/Buell Model: 883L
BIGTC and 07custom....thanks for the props...we appreciate your business!
DK Custom's Avatar
Originally Posted by lostNdallas View Post
I've bought several things from yall and over all I am very pleased with it. I have two minor issues. The first is the paint on my coil/ignition relocation mount is flaking. Powder coating might be more durable. A mini-texture would be awesome.
The second is that I could never get the ignition mounting screw to stay tight with the rubber isolator. Once removing the rubber isolator it stayed tight but I was concerned about the vibration prematurely wearing the key/tumbler. Your key relocation kit to the rear of the trans solved that problem for me.
thanks for making a good product. Makes me wish I still had access to my old machine shop.
Oh, and welcome to the forum.
Hey lostNdallas,
Thanks for the welcome AND your business.
We switched to Powder Coat early this year. If you want to send back the one you have we will replace it with a Powder Coated one, no cost.
Out of thousands of these installed we have not had one report of tumbler problems. I have had one on my sporty for over 20K miles and works the same as when I put it there.
The screw should stay tight with some medium blue threadlocker and if it is tightened down so the orange silicone is slightly compressed. If it doesn't the only thing I can think of is that the threads on the metal insert in the stock ignition housing are messed up.
Thanks man!
Old 8th November 2011
Geekster's Avatar
Geekster Geekster is offline
Other Motorcycle Model: Yamaha SRX-6
Other Motorcycle Year: 1986
Geekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond reputeGeekster has a reputation beyond repute
Default Key relocation
Ordered a key relocation - a refreshingly simple piece of hardware that will do a fine job, I'm sure. Sure has the looks!
Old 9th November 2011
lostNdallas's Avatar
lostNdallas lostNdallas is offline
lostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond repute
Originally Posted by DK Custom View Post
Hey lostNdallas,
Thanks man!
I will probably just buy another one since my bike never goes unridden for more than two days in a row. I have a powder goat guy here that does a mini-texture which matches the textured cases of my engine anyway.
As for the switch, after I removed the silicone pad is when I noticed the wear on the key and the switch was definitely getting notchy. I like the key location a lot better with the Flex-6 mount anyway.
thanks again,
John
The journey IS the destination. (L-1,C-1,R-3)
