Last Post: roadsterboy
Last Post: Airbozo
Last Post: _Outlaw
Last Post: mor
Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
backfiring, exhaust
Old 2nd November 2011
chinkr's Avatar
chinkr chinkr is offline
Other Motorcycle Model: Honda CB 550
Other Motorcycle Year: 1974
chinkr is an unknown quantity at this point
Default Exhaust Backfire issue
I have a 98 XL 1200 which just started backfiring thru the exhaust between shifts and just reving it in neutral when the rpms go down. Tried carb and timing adjmnts but it did nothing. It always did backfire a little upon deceleration, but not the between shift thing or just reving it in neutral. Plugs look real clean and not really brown . Also when I pull out the choke knob and rev it the backfiring will stop, but I could not adjust it richer with the air/fuel screw as it really did not change anything. The bike starts and runs great otherwise. Any ideas?
Pringles21's Avatar
Pringles21 Pringles21 is offline
Sportster/Buell Model: XLH883
Pringles21 is a name known to allPringles21 is a name known to allPringles21 is a name known to allPringles21 is a name known to allPringles21 is a name known to allPringles21 is a name known to allPringles21 is a name known to allPringles21 is a name known to allPringles21 is a name known to allPringles21 is a name known to allPringles21 is a name known to all
Check the exhaust gaskets and intake seals. While the bike is running spray some wd-40 near the intake seals on the heads and if the rpms change, you have a leak. I don't remember how to check the exhaust gaskets but those can cause the bike to run abit lean. Is your bike stock?
Banned
Your bike is probably lean.
http://www.sportster.org/tech/lee-c-...-instructions/
chinkr's Avatar
I bought bike used.Has screamin eagle pipes and a 170 jet in carb. Did the water spray thing on the intakes , but have not checked the exhaust gaskets etc for leaks.
chinkr's Avatar
Bike is stock but do have screamin eagle pipes on it.
sportsterpaul sportsterpaul is online now
Please check Shelle's reference thread and you will be shown the "light". Now let the bonding begin.
chinkr's Avatar
Where do I finf Shelle's thread?
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 3rd November 2011
Jim: Thanks for that, dumb me should realize that not everybody on the Forum knows who Shelle is, thanks again.
Banned
Scroll up to post number 3, I fixed it for ya
