Last Post: rickmodee
0 Leaks
Last Post: seanq2208
7 Long Road Trip advice
0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
0 Value of a Boattail?
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
0 Spring Seat Brackets?
Last Post: RussW
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
0 Head gaskets.
Last Post: 883openpipes
0 99 1200s clutch drag
Last Post: NZstu
Old 17th November 2011
kimosabe1960's Avatar
kimosabe1960 kimosabe1960 is offline
Other Motorcycle Model: Suzuki Cavalcade
Other Motorcycle Year: 1986
kimosabe1960 is an unknown quantity at this point
Default Part name
Hey all! On my 1999 I snapped a bolt on the fender strut. It was the rear one that holds the back rest and threads into a brace inside the fender. To remove it was a nightmare but got it out when I removed the fender. Since I'm doing a paint job I wasn't worried about the scratching I did but the bracket on the inside of the fender is now stripped of all the threads. I removed the bracket but don't know what it's called! I can't look for a replacement without knowing what the number or name of it is! Any help? Thanks, Joe
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
is it just a stamped piece of steel with nuts welded in it?? fixing it is probably faster, easier and cheaper than finding a new one........ can you post a pic of it??
Ww
master wizard
RIP Mr Jimi
"All The Way"
Yeah it's just a piece of steel with the round threaded inserts welded on each side that stick thru the holes in the fender. There are NO threads left in it so locktite wouldn't really hold it since it supports the fender, strut and back rest bracket. I thought about just getting a longer bolt to go thru it and putting a nut on it but there's already no room between that nut and the tire as it is.
Old 18th November 2011
Gcram399's Avatar
Gcram399 Gcram399 is offline
You could put in a Helicoil to restore it to the original thread size if you can't find a replacement part.
George
--Thomas Jefferson
racerwill's Avatar
that's a cheap, easy fix for anybody with a little fab and welding skills and tools.... if you don't have those, most machine shops have all that.....any chance you're located on the south coast of Boston?? I have everything you need.......
Ww
okayyyyyyy.... I just saw the Gulf of Mexico.... that would be a long ride to save a buck
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
http://partsfinder.onlinemicrofiche....=13&A=195&B=37
Part #23: HD Part # 59671-98. Around $65
You can look up your own parts using this thread:
http://xlforum.net/forums/s....php?t=1073066
Cosmo
