0 My last real nagging problem
0 N65C or N65A
0 check my chain?
Last Post: jcro61
0 Shotgun Porn
Last Post: robbie202
9 MAP code problems
0 Hillbilly Hot Dogs
Last Post: gravydog
0 Handlebar Question
Last Post: kluoto
0 Oil Pump upgrade
0 Removing powder coat?
Last Post: Oli1200
Last Post: ezmerf
0 new (to me) '82 25th Anniversary Edition XLH 1000
Last Post: eimkeith
0 Oil On Underside Of gas Tank
0 starting characteristics
Last Post: smac74
0 Replacement clutch discs
0 Sudden stiff rear brake pedal.
0 How dangerous is 2k clear coat really?
Last Post: Hugh Jasol
Last Post: spamer80
0 TC88A and Raptor shift light
0 Greetings from central Illinois
Last Post: 3dognate
0 Lost compression?
Last Post: frogg_nutts
0 Shop Arson
0 Thought my clutch went out or tranny, was front pulley
Last Post: kuri77
prbetts (71), 1988XL (67), jbcant (66), gearman (63), rejeanprimeau, Hdrider8831200 (57), AOW (50), adair727, Mechano (46), 64physhy, Buckshot (44)
Old 15th September 2005
emtech emtech is offline
Sportster/Buell Model: 1200c
emtech has disabled reputation
Default New tires
I have a '04 sporty 1200c. Looking for new tires. any suggestions? The Dunlaps lasted 15,000.
95xlcustom's Avatar
95xlcustom 95xlcustom is offline
Sportster/Buell Model: 1200 xl
95xlcustom has disabled reputation
go with them again thats good milage
RENE RENE is offline
RENE has disabled reputation
i got 5500 out of my rear dunlop
Old 16th September 2005
HD CRAZY's Avatar
HD CRAZY HD CRAZY is offline
HD CRAZY has disabled reputation
I got 10,000 out of my 1st rear factory Dunlop and only 8,000 out of the replacement Dunlop I put on. Just switched to the Avon Venom this time we'll see what kinda mileage I get out of them. But so far I really like how the feel alot better than the Dunlops.
Old 17th September 2005
wagoneer12's Avatar
wagoneer12 wagoneer12 is offline
Sportster/Buell Model: Sportster 883C
Sportster/Buell Model #2: Chopped XLH
Sportster/Buell Year #2: 1967
Other Motorcycle Model: 2007 Road King Classic
wagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the rough
I got 15k out of the front and 16k out of the rear (stock dunlops)
I went with them again, they performed fine and I got lotsa miles.
If you want more performance, try something else. If you are happy with the performance, 15k is pretty darn good. I expect that again out of this set.
Old 18th September 2005
petefwa petefwa is offline
petefwa has disabled reputation
I've got nearly 20k out of a Michelin Comander and it's still got a bit in it.
Moved On Moved On is offline
Be careful about buying a tire based on high mileage. The longer the tire lasts, the harder the rubber is, and the less traction it will give you. Dumlops are nice tires. Avons and Metzlers have softer rubber and may only give you about 10K miles but they will stick to the road better.
Gazza
Old 19th September 2005
Carl-04XL's Avatar
Carl-04XL Carl-04XL is offline
Sportster/Buell Model: XL1200R 'Ms Lily'
Carl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the rough
I only got about 12-15 "hundred" out of my first rear tire, but only because some idiot left a nail in the road and the tire found it.
I've only got 6934 on her at last fillup (about 1.4 miles ago) and expect to get around 10k or so. I was hard on my last bike and the tires didn't last as long as they could have. I expect to have the same type wear on my Sporty.
I'll be happy if I get more than 12k out of each tire.
Carl
Which way to the egret!
I am looking for tires that might give better handeling not nessaserally longer milage.
Bikerdude's Avatar
Bikerdude Bikerdude is offline
Sportster/Buell Model: Ironhead XLH
Sportster/Buell Year: 1985
Other Motorcycle Model: Ultra Classic-FLHTCUI
Bikerdude is an unknown quantity at this point
http://www.metzelermoto.com/media/me...t_bulletin.pdf
This tire would probably handle better according to many user reports.
BikerDude--Livin` the life~.
1985 Ironhead---1999 FLHTCUI
