Last Post: David L.
Last Post: Naplesron
Last Post: Grumpy-Biker
0 Lowboy frame conversion
0 Primary Oil INSANITY!
Last Post: randy3934
0 Left Side Exhaust?
Last Post: maltesefalcon
Last Post: blindfredy
Old 31st December 2011
bmel17 bmel17 is offline
bmel17 is an unknown quantity at this point
Default need help with head gaskets
I have an 08 nightster and have an oil leak from my heads. Is it worth it to have a shop fix it or is it easy enough to replace on my own? I am handy. I have a service manual somewhere. If I do do it myself, what gaskets should I go with, james, cometic or stock?
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
Head gasket..my preference would be cometic and yes very easy to do.
Everything stock on your scoot? If so .040 for gaskets.
In three words I can sum up everything I've learned about life: it goes on.
Old 1st January 2012
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
If it's rocker cover or rocker box gaskets, use HD gaskets.
04/07 1275 BFH heads .590 cams S&S 1.725 rockers TC88A HSR-45 S&S ac LSR 2-1
chief's Avatar
chief chief is offline
Location: mostley at home sometimes in the garage next to my sporty..
Sportster/Buell Model: XLH 883..
Sportster/Buell Year: 1987
Sportster/Buell Model #2: XL 1000
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Yamaha XJ 900
Other Motorcycle Year: 1991
chief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of lightchief is a glorious beacon of light
if you should do it yourself mostly depends on how comfortable you are in doing serious work on your sporty and where they do leak.
ig the rockerbox is leaking i'd say go for it or let your 6 year old kid do it.. there's nothing to it!
if it is the head gasket it gets a little more complicated. yes you can do it, but you need the correct tools like a torque wrench and such.
and never forget to give the headbolds a 1/4 tighter turn once they are at torque. i always torque the heads go out for a smoke and a coffee and then give the bolts the 1/4 extra turn. the coffe break give me the feeling the gaskets and cylinders can settle a little before the last stage of torquing
and for gaskets i like james..
typo's are just a way of saying: hey i'm dutch!
the dutch Sportster Chopping Bastard.
http://toxic-garage.blogspot.com <= the toxic garage blog
CTFS
thanks guys! I'll be all right doing it. I just wanted to make sure it wasn't anything crazy and if I had a shop do it, would I be wasting money.
I have all the tools too so it looks like I'll be good to go!
outside the box racing
Sportster/Buell Year: 99
Sportster/Buell Year #2: 2000
remember: loosen headbolts and rocker box bolts 1/4 turn at a time, until loose, working your way around. i usually pull both heads at once.
when putting rocker boxes back on, do one cylinder at a time, making sure that engine is rotated so valve pressure is relieved. after you button up the first box, wait for and ensure bleed down of the lifters before rotating the engine to do the next one. and after you button up the second rocker box WAIT AGAIN and ensure lifter bleed down before going any farther.
bleed down can take anywhere from 10 minutes to 30 minutes depending. you ensure bleed down when you can spin the pushrods by hand at the rocker arm. they will always have some pressure but if you can spin them (it will not be easy) it is safe to proceed without bending a valve or worse.
i don't use loctite of any kind anywhere in the top end. nowhere.
TGB #8
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
There's one place it's factory applied ... the rocker box top bolts.
Click Here to Contact Me
the 2 layers of rubber gaskets seem to do just fine at keeping them from backing out. IMO. but it is a fine line between just tight enough and too tight. one way you end up with spurting oil leak at exactly the wrong time an the other you have your rubber squeezed out.
some blue would make sense on these as long as the bolts are in good shape and haven't been torqued down too many times.
if you look at the bolt between the head and the threads and it appears slightly thinner in spots, that is where it has stretch and twisted due to torque.
this is where it is going to snap on you. replace them before you think about loctiting them or you will first be pissed and then sorry.
