0 Help with my clutch please
0 Lowboy frame conversion
0 C.O.B.B run west
Last Post: skien
Last Post: Bwf347
0 New 2017 H-D Street Rod XG750A
Last Post: Bone
0 Removing oil key from shaft
0 2003 1200 Custom riser
Last Post: ahusain
0 What's your helmet?
Last Post: The Crusher
0 Primary Oil INSANITY!
Last Post: ed_in_az
Old 4th January 2012
Foracer666 Foracer666 is offline
Sportster/Buell Year: 97
Foracer666 is an unknown quantity at this point
Default ring gap question,
I am in the process of doing 883-1200 conversion. i am using the wiseco 9.5 comp dished pistons . i bought the jugs and pistons from a friend of a friend .
they are 883 jugs bored. so i ordered new hastings rings for the wiseco pistons. so they rings came in today and i was curious what the end gap is .
so i used one of the new pistons to center the new ring about a inch in the bore . and i am seeing .020" i spoke to the wiseco guy and he was saying he runs like .014. and then i was searching and found nrhs uses .018" so will i be ok with what i have ? will it cause any problems in my build? i am sending my stock heads to nrhs for the stage one and i am install n4 cams . any help would be appreciated .
Default Gap
Can anyone help?
I know there alot of very knowledgeable
People out there.
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
http://www.cp-carrillo.com/LinkClick...Ls%3D&tabid=83
04/07 1275 BFH heads .590 cams S&S 1.725 rockers TC88A HSR-45 S&S ac LSR 2-1
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Rings are all made for a target bore size. Every .001" the bore is bigger than this target causes the ring gap to grow by just over .003". So a wide gap, on a set of rings that's supposed to be correct for the bore size, can easily be caused by problems with the bore. But I have no way of knowing if that's the case without making the measurements, and I'm certainly not saying that's what's going on here.
If it were me, I'd clamp the cylinders into torque plates, measure the bores, and measure the pistons, to see if the bores are straight and round and the correct size for the pistons. Only after I had confidence that was all correct would I make the call as to whether or not the gap was acceptable to me. If all that's right, and the gap was wider than what I want, I'd go get new rings.
Click Here to Contact Me
As said above what is your piston to cylinder wall clearance while the cylinders are in torque plates? If you want to send me your cylinders and pistons when you send me your heads I will be happy to check that for you at no charge if you do not have torque plates available.
Ok that's prob my best way to go!! And if there's a problem I always
Have my stock jugs to bore. Maybe just sell the stuff I have and
Go with one of your 1250 kits.
Any of the above would be a good choice.
Default Ring gap
So riddle me this .
I decided to check the gap for the second ring.
Now this a brand new set from wiesco.
The second ring I can barely fit a feeler gauge in between
It . So do I have a faulty top ring. Measured in both
Cylinders is like .019-.020.
Old 5th January 2012
Tattoo Tony's Avatar
Tattoo Tony Tattoo Tony is offline
Sportster/Buell Model: XL883N Iron
Tattoo Tony has a spectacular aura aboutTattoo Tony has a spectacular aura aboutTattoo Tony has a spectacular aura aboutTattoo Tony has a spectacular aura aboutTattoo Tony has a spectacular aura aboutTattoo Tony has a spectacular aura aboutTattoo Tony has a spectacular aura aboutTattoo Tony has a spectacular aura aboutTattoo Tony has a spectacular aura about
I would take Dan up on his offer to check everything for you.
2010 Iron. One BadAss, wanna be RatRide.
in the wind's Avatar
in the wind in the wind is offline
Senior Bike Builder
Sportster/Buell Model: 883 XL
in the wind has a brilliant futurein the wind has a brilliant futurein the wind has a brilliant futurein the wind has a brilliant futurein the wind has a brilliant futurein the wind has a brilliant futurein the wind has a brilliant futurein the wind has a brilliant futurein the wind has a brilliant futurein the wind has a brilliant futurein the wind has a brilliant future
yuuuuuuuuuuuuuuuuuuuup...
IN GOD WE TRUST
-- I LOVE YOU DAD- [url]http://xlforum.net/forums/showthread.php?t=561568[/url] --
IT IS WHAT IT IS - except for the sportster,it is what you make it
my KANSAS KUSTOM HARDTAIL build thread--- [url]http://xlforum.net/forums/showthread.php?t=822273[/url]
