0 1982 rubber oil hoses
Last Post: nigeldavid
Last Post: Bikeaholic
Last Post: Animosity
0 1975 Sportster
Last Post: Porkchop9
Last Post: SophieWillow
Last Post: 1Scooter
Last Post: 84rzv500r
Last Post: jeffro57
0 Indicators not flashing
Last Post: steve-o-
0 1975 Sportster
Last Post: bplinson
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
0 75 XLH Bendix Carb Spitting Gas - Video
Last Post: jibber
0 Gear and brake linkage
Last Post: 93trident
0 1965 XLRTT article
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
Old 5th January 2012
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Sportster/Buell Model: XLH883>1200 Paughco Rigid
Sportster/Buell Year: 1989
Nobody Special is on a distinguished roadNobody Special is on a distinguished road
Default Spacer width size to replace speedo drive unit?
Took off and traded my speedo unit. Prolly should have measured it first. Now I can not line the wheel up with any spacer combo I have.
Here is what I was able to dig up but not sure if it is correct. Or what it means I need to do.
H-D's sizes for units are: .523", .789", .823", .940", & 1.114"
OEM# 67127-84A
87-95 narrowglide It's .940 overall.
It has a .361 spacer where it fit into the wheel? Is that in the overall spec?
If any one has info on the speedo size vs how to set up the stock 19" mag without speedo It would be much appreciated.
http://vulcanworks.net/3-4-ID-Axle-Spacers-p-367.html
Old 10th January 2012
Does any one know what set up I need here? To run stock narrow 1989 mag with no speed drive.
From what I can tell i need to find a .275 ish for the right and a .970 for the left? Just got back from the HD shop with another wrong set of spacers.
Or if any one can tell me what the stock spacer should be, or if the size of speedo drive is correct in op.
"Okay, now I understand you have the speedo drive from the 84-94 Sportster.
My book says that speedo drive is .940 overall length also."
Your axle should be stepped so that there is not a spacer on the right side originally.
For the midglide, you should have
fork leg
.75 on the right
the wheel
.940 spacer or .94 speedo drive
.75 on the left.
fork leg
From another post. No way .75 on each side plus .940 on left will fit?
Old 14th January 2012
bustert bustert is online now
post a jpeg of what you want to do. are you needing a mock up of the speedo drive on the right side? is it the same used on the ih spoked wheel?
Old 16th January 2012
No speedo at all. Trying to figure out the size of the speedo I removed so I can replace it with the correct spacer and run the mag wheel. And if the speedo had the spacer built in or not as I do not have the unit anymore.
Im starting to wonder if the axle is the wrong year. Think it is a 91 if that matters. I was told they were the same til 04 I believe.
I'll take pics today and measure the axle and try and find ref some where as well.
sunchild2071's Avatar
sunchild2071 sunchild2071 is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLH1200
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Chopped Shovel
Other Motorcycle Year: 1978
sunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant future
Damn. Was working on one this weekend, but won't be home again until Friday. Mine is a 91, and I can measure for you this weekend, if that is not too late. If you don't get what you need before then, PM me just before the weekend and I'll measure for you.
Disclaimer: I'm not the expert on this stuff, be sure to seek further opinion/knowledge.
Old 23rd January 2012
ok nobody here is what i got.
right side speedo drive is .750 over-all with a shoulder of .310 wide that slips into the seal area.
left side spacer is .367 over-all, the spacer has a small .065 flange that tucks under the seal. i hope this helps.
Thanks! I'll get out here and give that a look. I know the speedo side was just over 1" by my guess so that looks right on.
I measured on my '91 this weekend (1200) and the overall width was 0.930", including the part that slips into the seal.
Old 24th January 2012
i guess i should have mentioned it is on a 74 ch with spoke wheels. also, but not included is the thickness of the caliber anchor which shouldn't matter to your setup.
I came up with 1.600 as the total spacer/speedo space, inclosing the offset space on axle of .425 at the right side.
So at .930 that would leave .245 for the right side. Just small enough to fit in the seal recess it looks like. Might even be washers? Does that ring a bell?
With a single disc 19" mag wheel? I came up with around .800+ So .930 looks like the best fit here.
So did you happen to measure the right side spacer then? Is it . 245 or .375 do you know?
Yeah the spoke wheels are dif. Also think the year range on the axle and speedo drive is 84-04.
