0 Cartridge Conversion?
0 How do you upshift?
Last Post: Sprtstr1200s
0 Photo Gallery for XL Forum Team Members!
0 This Week in my Shop
0 48 Handling
Last Post: Thyratron
Last Post: squekster
0 Error B2116 & 2117
Last Post: tester
5 To Hone Jugs if replace Piston Rings?
Last Post: groovemeisterus
0 79 starter housing torque values
0 Oil line routing on an 80
Old 6th January 2005
55 Jr's Avatar
55 Jr 55 Jr is offline
55 Jr is an unknown quantity at this point
Default Velocity Stack info for a Dumb Guy
Hey all.
So looking at my post count you may think I'm quite new here.
Not so.
My last ID "Brine" did not survive the change over.
No big deal, anyway I found you guys and I'm glad to be back.
Now some questions:
I've always liked the look of a bike with a velocity stack but I don't know squat about them.
First, how well do they breathe?
They any good at filtering? Or do you clean out the filter after every ride?
(They do filter right?....Fine screen I mean)
Where do you get one for a stock 40mm CV?
Do they look stupid on a stock carb? Do I need some (lots?) of chrome to pull this off?
I'm looking at doing a stage I this winter and beatin a Fat guy on a Valkarie next year.
(Remember me now?)
Thanks for your time and consideration!
Best regards,
Brian
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
I'm pretty sure most of the Velocity Stacks I've seen have a screen outside, but a foam sort of filter behind???? However, because they lack surface area, the filter media must be rather unrestrictive and therefore most likely lmore dirt is going to be getting into the engine. Since that is what causes significant wear on the cylinders, I would really check the one you are interested in carefully keeping this in mind.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Similar Threads
Velocity Stack??? HottRod Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 9 21st April 2005 23:15
A question on velocity stacks... Benetampa Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 2 28th February 2005 00:31
velocity stack benny04hd Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 2 26th February 2005 13:41
velocity stack vs a/c kev883 Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 7 3rd February 2005 23:53
