Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200
XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 For XR Sportsters: XR750, XR1000, XR1200
Last Post: Vohnsen
0 Fact or Fiction - HP Claims
0 More of a reintroduction
Last Post: spitfirechopper
0 Cylinder Piston kits
0 Clutch Spring plate poll
Last Post: NZstu
0 Trade Chrome for Black?
0 Bars on C Riser?
0 1967 XLCH stroker project
Last Post: kaveebee
0 crack in head
Last Post: slamtry
Last Post: 45Brit
Last Post: kaveebee
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
Old 5th February 2012
German61xlch's Avatar
German61xlch German61xlch is offline
Sportster/Buell Year: 1961
Sportster/Buell Model #2: XR 750
Sportster/Buell Year #2: 1980
Other Motorcycle Model: XR 1000
Other Motorcycle Year: 1983
German61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of lightGerman61xlch is a glorious beacon of light
Originally Posted by matsoberg View Post
My first thought and maybe what is done here, but my understanding is Andreas switched the whole unit (as of his text)? Wouldn´t mind getting one if it´s an original XLCR unit!
Yes, this is an original XLCR unit. I bought it from a friend in US, because I ´d like to keep all original parts unchanged for any reason in the future. But basically you can grind, switch and reweld the original one.
Best,
Andreas
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
Originally Posted by German61xlch View Post
a.f.a.i.r. around 500,-
You can ask Black Widow Cams, these cams should be still available...
Did they give you the specs and or graphing of the lobes over 720* on these?
No, I just try it. Seems to be a guy with lots of experience and selling these cams for years. As he told me these should be better than the original HD-E-cams.
Old 9th February 2012
chevelle's Avatar
I have been trying to get him to let me know the specs of these "E" cams
What are the HD specs and at what lift are they taken?.
All he said was they are HD Specs w/ a broader nose radius?
Have you done the head work to make these fit?
Do you know what to set the TDC clearance to?
These did fit without any mods. Bolt on...
The specs of the original HD E-cams I ve seen sometimes ago in the www, but cant remember exactly where.
Will tell you more after a first ride.
A
Old 10th February 2012
chevelle's Avatar
A
Finally got the specs from the guy at Blackwidow, after he was somewhat rude... anyway.
He said the lobe had a broader nose than factory E ....
I am not familiar w/ XR1000's head setup, but the TDC lifts on theses lobes are getting pretty radical, be cautious!
BW XR 1000 E CAMS
.444"/.444"
267*/269*
33/54 tdc .257
65/24 tdc .200
@.060"
Price is $525.00 + tax + freight
matsoberg matsoberg is offline
Sportster/Buell Model: XR1000
Sportster/Buell Year: 1984
Sportster/Buell Model #2: Buell X1
Other Motorcycle Model: EBR 1190 SX
Other Motorcycle Year: 2014
matsoberg is a name known to allmatsoberg is a name known to allmatsoberg is a name known to allmatsoberg is a name known to allmatsoberg is a name known to allmatsoberg is a name known to allmatsoberg is a name known to allmatsoberg is a name known to allmatsoberg is a name known to allmatsoberg is a name known to allmatsoberg is a name known to all
Chevelle
Here are the spec´s I got from Jerry Branch with my set of Sifton E-cams in 1989. I ws told this was the numbers of the originals.
Throttle on the right - Twist to go faster
chevelle's Avatar
Chevelle
Thanks matsoberg,
Those TDC #'s look closer to bolt in.
So it seems that blackwidow or whoever they got the cams from has drastically changed the after spec lobe profile. The TDC lifts are pretty radical..... Be careful w/ these blackwidow socalled "E" XR cams.
thanks for the numbers and the advise, I will doublecheck it....
Talk to you soon
A
Old 11th February 2012
chevelle's Avatar
Talk to you soon
A
Also when you get it running, you may need to experiment lashing the valves
(especially w/ these Blackwidow "E"'s)
On page 19 of Branches booklet, he explains this.
http://www.xr1000.de/external/manuals.html
