Last Post: Diogenes415
Last Post: BrokenIron
Last Post: lugster
0 Feeling in trouble.
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 Diagnostic help
Last Post: BradX13
0 If you have European tilt
7 Long Road Trip advice
Last Post: 38mini
Last Post: MatHormell
Last Post: kkbii
0 first harley- help!!
Last Post: r4fthrs
0 PACK YOUR BAGS SALE! Take 10% off 'Voyager' Series Luggage
Last Post: BILLETPROOF
Last Post: lo-rider
Last Post: runingmouse
0 Will you help out The XL Forum?
Last Post: bplinson
0 spoke nipple tool?
Last Post: Jollly Rogers
Old 28th January 2012
Question Winter Project - more questions
1. Testing the VOES
Is this correct? - with VOES disconnected and on the bench there should be no continuity between the two wires [to ground and from ign module]; with vacuum applied there should be continuity.
2. Lube'ing Cables
I clean the cables with brake&parts cleaner. Then i have always used a light oil for the throttle and clutch cables and a light grease for the speedo and tach cables. I do not recall why i have done them this way other than that they are different internally. There are more options now such as graphite spray and silicone spray. So what do you do?
3. Does the speedo drive gear ever need new grease or other lube? It cannot be dismantled but i suppose some grease could be injected with the cable removed [although i no longer have a grease gun]. What do you do with this?
4. How often to change the fork oil and brake fluid? Every year? Every other year? After so many miles?
Smerch's Avatar
Smerch Smerch is offline
Sportster/Buell Year: 1979
Smerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to allSmerch is a name known to all
1. Testing the VOES
That is correct. The ignition won't go to advance mode until it sees continuity caused by manifold vacuum (switch closed). If a wire gets cut or the vacuum line pops off the switch fails to safe, i.e. open/no continuity and the ignition stays in "retarded" mode.
#1 one way or the other, if it doesn't change the switch is bad....
#2 I don't "clean" the cables, I just dribble some Tri-Flow or Marvel oil down them.
#3 Don't need no stenkin speedo
#4 Fork oil = 5000 miles Brake fluid = no spec given, I would change when it becomes discolored
hmmm!!! the original speedo drive had a zerk on the bottom. yes a little lube helps as eventually the drive and worm will wear and the drive will try to climb the worn, lockup and bend the drive tang. two options, install a zerk or go to the drug store and buy a hyperdermic needle with a fair size hole and a seringe, make sure they are the twist lock design. then fill the seringe with grease and inject through drive tang plate seal. i use this method on sealed and shielded bearings. a good product is desco 220 made by chemola in beaumont,tx. for the speedo chain and if mixed 1/2 with grease, can be used in bearings. this product will go from flame bucket launch to the cold of space, burn it to nothing and it still lubes. this stuff is so slick, if put into a bearing, the ball will pass through it and not carry it around, so the need for grease. got a boat, mix with grease for trailer wheels and never worry about water. however, not recommended for tight tolerance bearings as this stuff plates itself to it.
dot 5 silicone fluid does not absorb water and really has an extremely long life unlike dot 3 which is glycol based and will absorb water and cause corrosion. the darker the fluid, the more water in it, swap every three years or if it becomes dark.
Old 29th January 2012
Thanx for the tips.
Yes, the VOES is toast. I picked off the silicon cap and tested while adjusting the screw one full turn, 1/8th turn at a time, each way. No joy.
I wonder how long it has been like that as i have not been getting any noticeable pinging, and i had installed that VOES as it was needed to get rid of the pinging - or so i thought anyway.
However in my spare parts i have an old VOES that tests good so i'll put that one on. I took this one off my 1980 a few years ago as it was not working. I did later get it working by resetting the screw.
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
Yep, always good to have spare parts around.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
I wonder how long it has been like that as i have not been getting any noticeable pinging, and i had installed that VOES as it was needed to get rid of the pinging - or so i thought anyway..
The VOES will default to the less advanced setting if it goes bad. So, you've been riding without full advance when the VOES would have allowed it. Your performance would have been marginally less with the bad switch, probably not noticeable under normal riding.
Eric
the beauty of the ultima ignition is that voes or not, the advance will be the same, just altered to be slower on ramp without voes and quicker on ramp with voes, unlike the hd module.
