Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Styles > Sportster Motorcycle Project
0 Need advice (Falters When Turning Corners)
0 Spokes or Mags
0 -75 ironhead, My first HD
0 Riding on Blood Thinners
0 Touratech Destino Boots Review
Last Post: MotoMoshe
0 Lowboy frame conversion
0 How do you upshift?
0 Oil Hose replacement help.
Last Post: Jollly Rogers
0 Stage 1 results
Last Post: 09Nightsterrider
0 Want to buy: solo saddle bracket and hardware
Last Post: Dsantizo2
0 Forty-Eight Special and Iron 1200 Sportsters announced today
Last Post: Jheitt
0 Solar battery charging
brake light, side mount, swingarm, wiring
Old 9th February 2012
jlongbrake's Avatar
jlongbrake jlongbrake is offline
Sportster/Buell Model: 883 Sportster
Sportster/Buell Model #2: Iron Head
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1998
jlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nicejlongbrake is just really nice
Default Side mount brake light wiring
I attempted to run my side mount liscence plate brake light wiring through my swingarm. I drilled a hole in the swingarm and vacuumed a string through, but when I tried to pull a wire through it hung up.
Tried for an hour before admitting defeat. Damn plugs!
Thank God, my daddy was a biker.
Grumpy_Chef's Avatar
Grumpy_Chef Grumpy_Chef is offline
Lord of the Flies
Other Motorcycle Model: Fatboy
Other Motorcycle Year: 1995
Grumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of lightGrumpy_Chef is a glorious beacon of light
did you try and pull one wire at a time?
Matt
'75 XLCH 1000
'95 FLST Fatboy
'83 GL1100 Goldwing (cafe project)
Old 10th February 2012
jlongbrake's Avatar
Yeah. I think there must have been a small hole that the thin string could get through, but the wire just couldn't make it.
I had the same problem when I tried to run wiring throug my handlebars. I could get a large gage wire through, but when I attempted to pull the wiring through it got hung up. I could probably manage to get them through one wire at a time but, after seeing a little marring on the wire I used to pull them through, I was afraid I would bite into my wiring, and eventually short out.
Old 12th February 2012
steve-o- steve-o- is offline
Sportster/Buell Model: XLH Ironhead
Sportster/Buell Model #2: Ironhead Basket (on lift)
Sportster/Buell Year #2: 1972
Other Motorcycle Model: FLH 80 Shovelhead
Other Motorcycle Year: 1981
steve-o- will become famous soon enoughsteve-o- will become famous soon enoughsteve-o- will become famous soon enoughsteve-o- will become famous soon enoughsteve-o- will become famous soon enoughsteve-o- will become famous soon enough
You just gotta really debur your holes (I use a small grinding ball on my "dremel") and try greasing-up the wires.
jlongbrake's Avatar
If you're refeing to my handlebar problem, then the holes were pre-drilled. It's the weld inside the bar that I'm hanging up on. The bars are not one solid bent tube, they are mitered and welded.
Old 13th February 2012
Didn't realize you were hangin'-up on welds. I've just seen too many scarred-up wires from nasty lookin' holes.
Old 19th February 2012
jlongbrake's Avatar
Good news!
Last night I managed to get my hand controls wires through the handlebars. It took about two hours because in order to stagger the wires to make the lead as thin as possible I had to cut the wires by the controls and solder them back together.
What a relief though. I have put a ton of hours on this bike so far, on this winter makeover, and if I had to have wires hanging it would have ruined the entire project. I contemplated on removing the controls all together and mounting a switch box somewhere, but last year I tried that and failed miserably - to the point of having to buy a new wiring harness.
Now that the wiring is all done, it's off to the next challenge. Molding the rear fender. Uhg!
