Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Lighting
0 Tap extention?
Last Post: T. Clark
0 Tank swap
Last Post: Grymy
0 How do you upshift?
0 Lowboy frame conversion
10 Anyone else noticed this? (Horn Closes Choke)
0 Oil Hose replacement help.
0 Spokes or Mags
0 New From CA
Last Post: jcro61
Last Post: MXHD55U
Last Post: Crosshairs
brake, electrical, led, light, tail light
Old 9th February 2012
mee73novass's Avatar
mee73novass mee73novass is offline
mee73novass has a spectacular aura aboutmee73novass has a spectacular aura aboutmee73novass has a spectacular aura aboutmee73novass has a spectacular aura aboutmee73novass has a spectacular aura aboutmee73novass has a spectacular aura aboutmee73novass has a spectacular aura aboutmee73novass has a spectacular aura aboutmee73novass has a spectacular aura aboutmee73novass has a spectacular aura aboutmee73novass has a spectacular aura about
Default Putco Neutron LED
Anyone out there using a Putc Neutron LED for a tail light? I've read that they are the brightest SOB's on the market, but at $50 a pop, I wanted to test the waters before diving in. Any feedback would be appreciated.
Old 10th February 2012
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
Got a link so we can help you decide?
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Here you go...
http://www.putco.com/products.cfm?ac...5-b085cb11ab2b
il67bp's Avatar
il67bp il67bp is offline
il67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to all
One obvious difference is that they do not throw light out to the sides rendering the internal refelctors in our stock lights useless.
MidnightExpress's Avatar
MidnightExpress MidnightExpress is offline
MidnightExpress is a name known to allMidnightExpress is a name known to allMidnightExpress is a name known to allMidnightExpress is a name known to allMidnightExpress is a name known to allMidnightExpress is a name known to allMidnightExpress is a name known to allMidnightExpress is a name known to allMidnightExpress is a name known to allMidnightExpress is a name known to allMidnightExpress is a name known to all
^ What he said. I've run LED "replacement bulbs" before, and you end up with a small (<1") dot that's really bright. Works okay (just "okay") at night, but good luck being seen during the day. Bright is nice, but when there's only 3 diodes, it'll be hard to get any kind of coverage.
I'd highly recommend anything from Radiantz. Or at least something with "full coverage" LED boards.
"Short is the pain. Long is the memory."
Gary Thrasher (1948-2010)
Ron Baldridge (1955-2011)
Old 11th February 2012
Thanks guys, I appreciate the recommendations and advice!!!
