0 Value of a Boattail?
Last Post: CMCSSeabee
0 1967 XLCH stroker project
Last Post: kaveebee
Last Post: r4fthrs
Last Post: cotton1
0 Clutch cable options
Last Post: BWP 5p
0 Diagnostic help
Last Post: BradX13
0 Not charging issue!
0 Brake Squeek
Last Post: seajay
0 Cylinder Piston kits
Last Post: seajay
0 how many miles are to many miles
Last Post: Turbo Sporty 48
0 Thinking of building a custom blast...
0 Vance and Hines Code:REaD
0 Head gaskets.
Last Post: cotton1
Last Post: hexnut
0 1988 106 inch build ( agent orange )
Last Post: Will1250
0 Won't rev past 1200
Last Post: Aocasio
0 z bars
Last Post: lucifer_mr2
Last Post: big andy
Old 4th January 2008
SpringerSam's Avatar
SpringerSam SpringerSam is offline
Sportster/Buell Year: 70
Sportster/Buell Model #2: Softail Springer
SpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished road
Default .070 Over
I am in the process of replacing the rings on my 900 and they were stamped
.070 over. I ordered a set and to my surprise, they were way to small. I took one of the cyliners to the local dealer and after measuring the bore, I found out I had 1000 jugs on my motor. I had no idea that this was even possible. In any event, has anyone else have this situation? Would they be the original heads? Is there a large performance increase over stock? Is it possible to go back to stock equipment or did it require modifying the block?
Thanks,
Sam
Old 5th January 2008
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 2008
Other Motorcycle Model: XLRTT
Dytch used to make 3"3/16 jugs (and pistons...) for old 900 from the early 60's. Normally the cyls are cast marked "Front" and "Rear" on the left hand side. They needed the crankcase cyl bores enlarged obviously.
These were std height and usually for use with stocker pistons.
So check your stroke as well!!!
The 900 heads needed machining to fit on the Dytch cyls and use bigger head gaskets. The 1000 OEM gasket can be made to fit these, otherwise, trim some 900 head gaskets to suit.
Patrick
Flat Head Forever
