0 Brake Squeek
Last Post: Tucsonmax1
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Not charging issue!
0 1977 Bright Blue
Last Post: robistro
Last Post: T^2
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
Old 23rd February 2012
sexpanther's Avatar
sexpanther sexpanther is offline
Sportster/Buell Model: 883 iron
sexpanther is a glorious beacon of lightsexpanther is a glorious beacon of lightsexpanther is a glorious beacon of lightsexpanther is a glorious beacon of lightsexpanther is a glorious beacon of lightsexpanther is a glorious beacon of lightsexpanther is a glorious beacon of lightsexpanther is a glorious beacon of lightsexpanther is a glorious beacon of lightsexpanther is a glorious beacon of lightsexpanther is a glorious beacon of light
Default bar drilling
hey folks. all my stuff finally arrived for my bar change out.
got some sweet 12" apes from biltwell however they are dimpled.
going to need to drill them to wire internally, but heres where i need the help - where in the dimple do i drill the hole for the wire to enter the bars?
ive taken a pic and color marked some positions where i think i should drill. please have a look and let me know which color is the right area! this is the left hand clutch side:
thanks for all the help guys it is much appreciated
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Put your hand controls on it and look it will be staring at you. I always drill in the middle, your red dot. Then i get a die grinder out and widen and smooth towards the blue and yellow dot. The more oblong you make it, the easier it will be. make sure you run the die grinder in the bar to get rid of any burs, or a hand file. spray some juice on your wires and they will slide in nice
sexpanther's Avatar
thanks madnss, will give it a go!
Old 24th February 2012
ESS ESS is offline
ESS is an unknown quantity at this point
I like to drill mine where the yellow circle is. I use three different size bits for the control holes. I start with 1/8", then 3/8" and finish with 1/2". I start the 1/8" straight, but by the time I get to the 1/2" I've angled the drill bit so the wires will have more of a straight shot into the bars. For the wiring exit slot I drill three 1/8" holes first and then follow that with the 3/8" bit so the holes just touch. You can wiggle the bit to connect the holes. Sometimes I just get a small cut off wheel on my dremel to finish the slot since I'm going to use the dremel next anyway. After holes are drilled and exit hole is slotted I put a small fine sanding drum (1/4" x 1/2") on the dremel and carefully clean up the sharp edges.
Also, make sure to protect the rest of the bar. I use a couple layers of blue tape around the hole area I don't want accidentally damaged. I cover the rest of the bar with some shop rags held on by blue tape. This is especially helpful with black bars. They scratch very easily and the drill bit or dremel can sometimes get away. Accidents happen. For the black bars I finish the bare areas with touch up paint. For chrome I'll use some clear nail polish to seal it and prevent any rust.
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
where you have the yellow circle ,is where I drilled mine(1/2")
In three words I can sum up everything I've learned about life: it goes on.
perk85's Avatar
perk85 perk85 is offline
Sportster/Buell Model: 1200
perk85 is an unknown quantity at this point
exactly what i did on my friscos
