Last Post: Bwf347
0 New 2017 H-D Street Rod XG750A
Last Post: Bone
0 Removing oil key from shaft
Last Post: mac93
0 2003 1200 Custom riser
Last Post: ahusain
0 What's your helmet?
Last Post: The Crusher
0 Primary Oil INSANITY!
Last Post: ed_in_az
0 Did I buy the wrong length chain?
Last Post: Yochstein
0 Tuning
0 Who Runs Turn Signals?
Last Post: vagrant318
Last Post: Lethrnek9296
Old 23rd February 2012
kenundrum's Avatar
kenundrum kenundrum is offline
Sportster/Buell Model: rigid x1 lightning
kenundrum is an unknown quantity at this point
Exclamation how to stop fluid leak on foot clutch cable
Cut the stock cable on my ridgid buell in order to set up a foot clutch. It works great but sport-trans fluid leaks between the actual cable and the hard plastic sheething. Anyone got any ideas on how to stop the leak besides re routing the cable to a higher position?
Old 24th February 2012
kenundrum's Avatar
Exclamation
nothing? wow
try putting some slack in the cable where it can be lifted out of the case adapter. now cut a piece of vacuum hose that the id fits snug as possible on the cable and about 1/2 half as long as the hole is deep and re-apply the cable. hopefully, the hose will act as a compression o-ring and squeeze off the leak.
kenundrum's Avatar
Great idea. I'll try it and get back to the forum.
Old 25th February 2012
kenundrum's Avatar
Well I tried to put a piece of rubber around the cable with no luck, however, I used a small thin O ring and shoved it inbetween the cable and the sheething. It stopped leaking.
Old 27th February 2012
rob_d's Avatar
rob_d rob_d is offline
Sportster/Buell Model: XL883C
rob_d is an unknown quantity at this point
I'm almost wondering if some heat shrink tube might work...just a thought. So far, mine isn't leaking...knock on wood..but if it does, I may give that a try. The o-ring is a good idea too...
