0 1974 Ironhead
0 24633-77 Breather assembly
0 Ei
Last Post: Serious Blac
0 New from Utah
0 Post season carnage
0 De-lowing a Superlow with Progressive Monotubes?
Last Post: FuriousGeorg
0 Exhaust Clamp Fitting
Last Post: Yochstein
Last Post: norseXL
0 Rubber mount Oil tank Vent line Routing
0 Need help on bolt size - 92 XL1200, mid pegs
Last Post: r4fthrs
0 Reflectors...Yeah, or Neh
Last Post: 60weight
0 1250 Conversion troubles
Old 27th September 2005
rambo rambo is offline
rambo has disabled reputation
Default last fork oil question for me??
ok, i think i got it, changed fork oil last night, put the oz. in like book calls for, all back together and ready to ride, but, do you have to "bleed" air out like you do in brakes?? no bleeding ??, when you pump the fluid out and it is all out, air has to be sucking in,, no?? thanks
oh, forgot, do not try to put fork top bolt back on without the right socket, took off with big wrench, but next to impossible to get back on without socket, (ran and bought one last night), i also did not get any fluid anywhere, how?? i cut some big garbage bags, inserted, let all oil drain in bag, no oil on brakes, rotor, or any where, barely any cleanup after this..rambo
No bleeding necessary because you don't completely fill the forks... so air will rise through the fluid into the open space above the fluid.
